Salta al contenuto principale
Microsoft Zune HD Controls Sidebar Replacement
Cosa ti serve
  1. Microsoft Zune HD Controls Sidebar Replacement, Upper Rear Panel: passo 1, immagine 1 di 1
    • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
  2. Microsoft Zune HD Controls Sidebar Replacement: passo 2, immagine 1 di 2 Microsoft Zune HD Controls Sidebar Replacement: passo 2, immagine 2 di 2
    • Slightly rotate the top edge of the upper rear panel away from the Zune.
    • Lift the upper rear panel straight up off the black plastic lower rear panel.
  3. Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: passo 3, immagine 1 di 2 Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: passo 3, immagine 2 di 2
    • Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
    • Try not excessively rotate the media button lever about this post.
Conclusione
Un commento
Can the side panels (hello from Seattle) come off as well?
Evoke - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,126
