Salta al contenuto principale
Microsoft Surface Pro X SSD and SIM Card Door Removal
Cosa ti serve
  1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: passo 1, immagine 1 di 2 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: passo 1, immagine 2 di 2
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: passo 2, immagine 1 di 2 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: passo 2, immagine 2 di 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD and SIM Card Door Removal, Remove the SSD and SIM card door: passo 3, immagine 1 di 1
Conclusione
Adam O'Camb
Membro da: 04/11/15
196.940 Reputazione
416 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 131
Tutti i Tempi: 9,461
