Salta al contenuto principale
Microsoft Surface Pro 3 Rear Facing Camera Replacement
Cosa ti serve
  1. Microsoft Surface Pro 3 Rear Facing Camera Replacement, Display: passo 1, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement, Display: passo 1, immagine 2 di 2
    • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
    • The display is strongly glued to the frame of the device.
    • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
    • Be careful when using a heat gun, as too much heat can permanently damage the display and/or battery.
    • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
  2. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 2, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 2, immagine 2 di 2
    • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
    • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
    • Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
    • Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
    • Work carefully—the glass is thin and will crack easily if you try to force it.
    • The wi-fi antennas are glued under the screen border along the top edge (on either side of the camera), and can be damaged easily. Use extra care when separating the top edge, and apply more heat if necessary.
  3. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 3, immagine 1 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 3, immagine 2 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 3, immagine 3 di 3
    • Continue to heat sections of the screen with the heat gun.
    • As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
    • The screen is extremely thin and very easy to break. Be careful working with broken glass.
  4. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 4, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 4, immagine 2 di 2
    • Lift the screen up carefully so that no wires are torn.
  5. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 5, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 5, immagine 2 di 2
    • Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
    • Be careful not lose the small, rectangular bridge connector that lies underneath.
  6. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 6, immagine 1 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 6, immagine 2 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 6, immagine 3 di 3
    • Remove the single 4 mm T3 Torx screw securing the display cable.
    • Lift the connector to disconnect the cable.
  7. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 7, immagine 1 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 7, immagine 2 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 7, immagine 3 di 3
    • Grasp the orange cable connected to the silver connecter.
    • Carefully lift the orange cable up until the connecter pops off.
    • The screen will now be completely disconnected.
    • The replacement display may not include all the parts needed for installation. Save all the parts from the original display, and transfer them to the new display as needed.
  8. Microsoft Surface Pro 3 Rear Facing Camera Replacement, Rear Facing Camera: passo 8, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement, Rear Facing Camera: passo 8, immagine 2 di 2
    • Remove the 4mm screw with the T3 Torx Screwdriver.
    • Remove the four 7mm screws with the T3 Torx Screwdriver.
  9. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 9, immagine 1 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 9, immagine 2 di 3 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 9, immagine 3 di 3
    • Locate the black piece shown.
    • Remove this piece by gently lifting it up with the tweezers until it pops off.
  10. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 10, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 10, immagine 2 di 2
    • Remove the two 4mm screws with the T5 Torx Screwdriver.
  11. Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 11, immagine 1 di 2 Microsoft Surface Pro 3 Rear Facing Camera Replacement: passo 11, immagine 2 di 2
    • Remove the rear camera with the tweezers.
Conclusione
Altre 2 persone hanno completato questa guida.
Erik Snyder
Membro da: 10/01/15
5.235 Reputazione
5 Guide realizzate
Cal Poly, Team 12-18, Maness Fall 2015 Membro di Cal Poly, Team 12-18, Maness Fall 2015
CPSU-MANESS-F15S12G18
5 Membri
31 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 3,401
