Salta al contenuto principale
Microsoft Band 2 Battery Replacement
Cosa ti serve
  1. Microsoft Band 2 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: passo 2, immagine 1 di 1
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: passo 4, immagine 1 di 2 Microsoft Band 2 Battery Replacement: passo 4, immagine 2 di 2
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: passo 5, immagine 1 di 2 Microsoft Band 2 Battery Replacement: passo 5, immagine 2 di 2
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: passo 6, immagine 1 di 2 Microsoft Band 2 Battery Replacement: passo 6, immagine 2 di 2
    • Pry out the battery using the plastic opening tool.
Conclusione
Altre 20 persone hanno completato questa guida.
USF Tampa, Team S1-G5, Leahy Spring 2017 Membro di USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
3 Membri
5 Guide realizzate
14 Commenti
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Replica
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Replica
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Replica
The only place i found was ebay:
ftlay - Replica
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 29
Tutti i Tempi: 12,850
