Introduzione
Is your projector overheating? Is it powering down at random times? Use this guide to replace the malfunctioning fan. Replacing the fan requires a fine tip soldering iron and should be done by those with solder experience.
Parti
Nessuna parte richiesta.
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver. Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Aggiungi Commento
Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
  • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
  • The bottom right panel screw does not come completely out the panel door.
Aggiungi Commento
Using your hands, gently pry the top and bottom of the projector casing apart. Using your hands, gently pry the top and bottom of the projector casing apart.
  • Using your hands, gently pry the top and bottom of the projector casing apart.
Aggiungi Commento
Locate the 80 mm fan and slide upward straight out of the housing. Locate the 80 mm fan and slide upward straight out of the housing.
  • Locate the 80 mm fan and slide upward straight out of the housing.
Aggiungi Commento
Unsolder the red and black connections off of the motherboard. If there are zip ties around the cables, they will need to  be cut to remove the fan.
  • Unsolder the red and black connections off of the motherboard.
  • If there are zip ties around the cables, they will need to be cut to remove the fan.
  • Need some help? Follow this guide to learn soldering basics.
  • While soldering the metal connections will get very hot. Never touch the iron with your hand.
  • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
  • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
Aggiungi Commento
Conclusione
Stephanie
Membro da: 08/01/2015
210 Reputazione
2 Guide realizzate
Cal Poly, Team 18-3, Maness Winter 2015 Membro di Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,063
