Introduzione
The speaker can be easily removed from the back cover.
Parti
Nessuna parte richiesta.
Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth. Please note: this is a tedious process, but be patient.
  • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
  • Please note: this is a tedious process, but be patient.
Aggiungi Commento
Remove the 4 screws holding the cover in place using a Philips #00 screwdriver.
  • Remove the 4 screws holding the cover in place using a Philips #00 screwdriver.
Aggiungi Commento
Open the back cover. Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
  • Open the back cover.
  • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
Aggiungi Commento
Disconnect the speaker from the terminal. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
  • Disconnect the speaker from the terminal.
  • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
In my 1200, the speaker is glued to the back and soldered into the board so there is no plug to undo. Just carefully find a position so that board doesn't pull on the speaker wire while it is open.
Jomar - Replica
where can we get the speakers from? please
bbunni1404 - Replica
Once you pull off the back cover, remove the orange piece of tape on the speaker. Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing. Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
  • Once you pull off the back cover, remove the orange piece of tape on the speaker.
  • Use a Philips #00 screwdriver to remove the 2 screws holding the speaker to the back casing.
Aggiungi Commento
Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
  • Once the speaker has been unscrewed, remove the speaker from the back casing with your fingers.
Aggiungi Commento
Conclusione
Ross Light
Membro da: 12/04/2010
175 Reputazione
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,947
