Introduzione
Use this as a guide to replace or remove the rear case.
Use tweezers to completely remove the sticker from the rear of controller.
  • Use tweezers to completely remove the sticker from the rear of controller.
Aggiungi Commento
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Aggiungi Commento
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases. Use the plastic opening tool to pry the two cases apart.
  • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
  • Use the plastic opening tool to pry the two cases apart.
Aggiungi Commento
Remove the two rubber side grips. Remove the two rubber side grips.
  • Remove the two rubber side grips.
Aggiungi Commento
Conclusione
Jefferson Hsu
Membro da: 18/09/2012
408 Reputazione
3 Guide realizzate
Cal Poly, Team 1-7, Propen Fall 2012 Membro di Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 718
