Introduzione
Use this as a guide to remove the motherboard so you can access the FightPad's buttons and directional pad.
Use tweezers to completely remove the sticker from the rear of controller.
  • Use tweezers to completely remove the sticker from the rear of controller.
Aggiungi Commento
Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
Aggiungi Commento
Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases. Use the plastic opening tool to pry the two cases apart.
  • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
  • Use the plastic opening tool to pry the two cases apart.
Aggiungi Commento
Remove the two rubber side grips. Remove the two rubber side grips.
  • Remove the two rubber side grips.
Aggiungi Commento
Locate RS-DP-LS switch. Pull upwards on the switch to remove it.
  • Locate RS-DP-LS switch.
  • Pull upwards on the switch to remove it.
Aggiungi Commento
Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
Aggiungi Commento
Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board. Be careful with the wires connected to the circuit board itself as they are thin and delicate. When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
  • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
  • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
  • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
Aggiungi Commento
Conclusione
Jefferson Hsu
Membro da: 18/09/2012
408 Reputazione
3 Guide realizzate
Cal Poly, Team 1-7, Propen Fall 2012 Membro di Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,617
