Introduzione
Please remember that these controllers are not designed to be repaired so do not be surprised if you need to be rough with it or something was not initially installed correctly. Also, the same kind of screw was used throughout the controller.
Parti
Nessuna parte richiesta.
Remove the six 7 mm Phillips screws from the rear cover.
  • Remove the six 7 mm Phillips screws from the rear cover.
Aggiungi Commento
Remove the back of the controller. There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  • Remove the back of the controller.
  • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
Aggiungi Commento
Conclusione
Alexander Coyne
Membro da: 11/01/2015
604 Reputazione
5 Guide realizzate
USF Tampa, Team 7-2, Remmell Winter 2015 Membro di USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 103
