Salta al contenuto principale
Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement
Cosa ti serve
  1. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement, Remove Cover: passo 1, immagine 1 di 1
    • Remove the six 7 mm Phillips screws from the rear cover.
  2. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: passo 2, immagine 1 di 1
    • Remove the back of the controller.
    • There are no loose items in the controller that can fall out, so you can open it, generally, however you want.
  3. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: passo 3, immagine 1 di 1
    • Remove the two 7 mm screws on the closest circuit board.
  4. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: passo 4, immagine 1 di 2 Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: passo 4, immagine 2 di 2
    • Lift the closest circuit board away from the motherboard.
    • Be sure you do not tear the ribbon connecting the smaller circuit board to the motherboard.
  5. Mad Catz Dual Force 2 Pro Analog Joystick Covers Replacement: passo 5, immagine 1 di 1
    • Grip the analog stick you wish to remove and the smaller circuit board or the cover.
    • Pull the analog stick from the smaller circuit board.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 7-2, Remmell Winter 2015 Membro di USF Tampa, Team 7-2, Remmell Winter 2015
USFT-REMMELL-W15S7G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 604
