Parti
Nessuna parte richiesta.
The battery compartment is located in the front-right side of the laptop.
  • The battery compartment is located in the front-right side of the laptop.
Aggiungi Commento
To insert the battery, gently slide it into the compartment until it clicks in place.
  • To insert the battery, gently slide it into the compartment until it clicks in place.
  • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
This is not to remove the battery, this is to remove the expansion slot (which has got the floppy disk module in it, in the first picture.
blrutter - Replica
Sorry I should have mentioned it in my prior comment. The battery has got a release button on it too, but it’s part of the battery, exposed on the front face of the right front corner when the battery is installed.
blrutter - Replica
With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
Aggiungi Commento
Carefully pull up on the front of the keyboard to pop it out from the case. Then slide the back out so the keyboard becomes nearly free.
  • Carefully pull up on the front of the keyboard to pop it out from the case.
  • Then slide the back out so the keyboard becomes nearly free.
Aggiungi Commento
Disconnect the ribbon that is connecting the keyboard to the rest of the computer. Pull the keyboard out and repair or replace as needed. Pull the keyboard out and repair or replace as needed.
  • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
  • Pull the keyboard out and repair or replace as needed.
Aggiungi Commento
Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary. Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
  • Remove the RAM board located underneath the keyboard by carefully popping it out from its connection. Reinstall or replace as necessary.
Aggiungi Commento
Conclusione
Ronan
Membro da: 10/10/2011
42 Reputazione
4 Guide realizzate
Cal Poly, Team 6-1, Regan Fall 2011 Membro di Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 622
