Salta al contenuto principale
Macintosh Powerbook 5300cs Hard Drive Replacement
Cosa ti serve
  1. Macintosh Powerbook 5300cs Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 2, immagine 1 di 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Hard Drive Replacement, Keyboard: passo 3, immagine 1 di 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 4, immagine 1 di 2 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 4, immagine 2 di 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 5, immagine 1 di 3 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 5, immagine 2 di 3 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 5, immagine 3 di 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 3 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 3 Macintosh Powerbook 5300cs Hard Drive Replacement, Hard Drive: passo 6, immagine 3 di 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 7, immagine 1 di 1
    • With a Torx #9 screwdriver, remove the three .30 in. screws that hold the metal frame in place.
  8. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 8, immagine 1 di 3 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 8, immagine 2 di 3 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 8, immagine 3 di 3
    • Remove the metal chasis that holds the hard drive.
  9. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 9, immagine 1 di 1
    • In order to remove the hard drive, remove the four .22 in. screws circled in red found on both sides of the metal chassis with a Torx #9 screwdriver.
  10. Macintosh Powerbook 5300cs Hard Drive Replacement: passo 10, immagine 1 di 2 Macintosh Powerbook 5300cs Hard Drive Replacement: passo 10, immagine 2 di 2
    • Pull the hard drive out.
Conclusione
Altre 2 persone hanno completato questa guida.
Ronan
Membro da: 10/10/11
63 Reputazione
4 Guide realizzate
Cal Poly, Team 6-1, Regan Fall 2011 Membro di Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,736
