Salta al contenuto principale
Macintosh PowerBook 1400 Series Keyboard Replacement
Cosa ti serve
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 3, immagine 1 di 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: passo 4, immagine 1 di 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 5, immagine 1 di 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 6, immagine 1 di 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: passo 7, immagine 1 di 1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 8, immagine 1 di 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 9, immagine 1 di 1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 10, immagine 1 di 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 11, immagine 1 di 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 12, immagine 1 di 1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 13, immagine 1 di 1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 14, immagine 1 di 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 15, immagine 1 di 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 16, immagine 1 di 1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 17, immagine 1 di 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 18, immagine 1 di 1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: passo 19, immagine 1 di 1
    • Remove the keyboard.
Conclusione
Sean Bent
Membro da: 04/01/11
41 Reputazione
1 Guida realizzata
Cal Poly, Team 10-39, Forte Spring 2011 Membro di Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,439
