Salta al contenuto principale
Macintosh IIsi Hard Drive Replacement
Cosa ti serve
  1. Macintosh IIsi Hard Drive Replacement, Top Case: passo 1, immagine 1 di 2 Macintosh IIsi Hard Drive Replacement, Top Case: passo 1, immagine 2 di 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Hard Drive Replacement: passo 2, immagine 1 di 3 Macintosh IIsi Hard Drive Replacement: passo 2, immagine 2 di 3 Macintosh IIsi Hard Drive Replacement: passo 2, immagine 3 di 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Hard Drive Replacement, Hard Drive: passo 3, immagine 1 di 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: passo 3, immagine 2 di 3 Macintosh IIsi Hard Drive Replacement, Hard Drive: passo 3, immagine 3 di 3
    • The Macintosh IIsi's hard drive is located ajacent to the ram and floppy drive.
    • Start by pushing these two tabs out, and lifting the drive up.
    • Then, flip the drive over, and remove the connection cables.
  4. Macintosh IIsi Hard Drive Replacement: passo 4, immagine 1 di 3 Macintosh IIsi Hard Drive Replacement: passo 4, immagine 2 di 3 Macintosh IIsi Hard Drive Replacement: passo 4, immagine 3 di 3
    • The hard drive: A Quantum ProDrive LPS, made in 1990, and surprisingly, it still works!
    • This drive has an 80MB capacity, not very large by today's standards, but not bad way back then...
    • Believe it or not, hard drive construction hasn't changed much in the last 20 years. Other than a few new interfaces, the form factor, 3.5" width and 4-Pin 12V/5V power connector has stayed the same.
Conclusione
Altre 4 persone hanno completato questa guida.
Chris Green
Membro da: 10/11/09
37.026 Reputazione
49 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
2 Commenti
Hello cano you please tell me how is the jumpering setting for a Quantum Prodrive LT 700MB
Juan - Replica
Is there a way to read the HDD on a PC?
Charles - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,964
