Introduzione
Replacing the MagSafe DC-In board requires removal of the logic board.
Remove the following ten screws securing the lower case to the upper case:
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
Step 1 (technically step 9 - replacing the base plate) Apparently one of my screws was a micron or two smaller than the others. This screw belongs to the hole above the optical drive, which is also apparently a couple of microns smaller than the others. It took seven attempts to figure which screw had originally been in that hole; all the other screws were too large, but fitted perfectly everywhere else.
Bizarre much?
Will - Replica
It might be a matter of how the screws are driven in, and not that they're slightly different sizes. When I reassembled my MacBook, a couple of the screws, including the one over the optical drive you mention, were hard to drive in and jutted up a little bit instead of sitting entirely flush. Swapping screws didn't help. The solution was to unscrew them and drive them in at a bit of an angle - perpendicular to the slightly curved surface of the back plate where the screw holes were, instead of fully vertical with respect to the ground the Macbook is sitting on. Doing it that way, the screws were easier to drive in and they all ended up flush in their holes. Didn't matter which screws they were. (I swapped a few around just to check after reading this.)
Andrew Janke -
I had no such screw issues. Either there are differences in manufacturing lots or I just got incredibly lucky during reassembly!
xtophr -
I discovered a great way of organizing the screws. I used an ice cube tray and added the screws in order, keeping the different kinds together. So when it came to reversing the steps, the screw order was an added control step to returning everything in its place.
leonie - Replica
Great advise! Love it! :)
Ririds -
I used to do that and that worked really great until I bumped it by accident and the entire tray went on the rug! I spent the next day sorting things out.
Now I use these:
http://www.sciplus.com/p/50-114-CLEAR-PL...
The lower ones 50 to a package. I mark them w/ blue tape. Often if it's part like the fans, or the optical drive I'll tape the screws into/near the holes where they belong. I did this a lot especially w/ the bottom screws from MBPs until I'd done so many I knew exactly where the longer ones went.
Richard Sato -
I wrapped the screws in a piece of blue masking tape and wrote the number on the little pouch I made. Then I stuck the blue tape pouches on the underside of the case bottom in order.
Roscoe -
I take double-sided tape, put that on a piece of paper, stick the crews to that, and label them.
jelimoore -
Best I've found is a bead sorting tray. They're like $5 at Wal-Mart and they have a lid that seals up and won't let them jump between containers.
maccentric -
I take a sheet of paper, pierce the screws through the paper, take a pen and box the screws and write out what step they belong to.
Nils -
@Will, in my case I had the same result as you did. As a reminder to myself the next time I need to open the computer, I put a dot of white paint on those two screw's head and a very, very thin ring of white on the very edge of each hole, that way I'll know they go into those two holes.
Roger - Replica
Actually the four screws on the bottom were not threaded all the way up. I didn't check to see if the thread gauge was the same on them, but it wasn't until I had about four screws out (I didn't take them out in the order that the bottom all came out first) that I noticed a difference. I then took out the rest of the bottom ones to see if they matched the two that were already out that weren't threaded to the top. They did. So I went under the assumption that those were all bottom screws and when I put it back together everything went fine with no resistance.
So there are three types of screws: Four for the bottom, three long ones as indicated and three others that might be slightly smaller than the bottom ones.
wresnick - Replica
Hi,
Although its more than a year since your contribution, I thought you might be amused to know that it is not just that the screws go in more easily when at an angle, Apple actually drilled and tapped the holes at a 15% angle. I too had tried to drive them in straight. An Apple "genius" - I was in for something else - clarified the design for me. It was done so that the screws lay flush on the angled part of the lower case. Nice design, but since Apple encourages DIY memory and drive changes, they could have mentioned this little ... trap.
H Stahl -
MacBookPro8,2
Intel Core i7, 2,2 GHz, RAM 16 GB
Mountain Lion
May someone help me?
I have installed the second drive with ssd 840 evo, but when I try to copy the file from the new drive to the main hd this in not allowed (errore -36)
Piero - Replica
To my knowledge you can't transfer a single file more than 4gb. I advise compressing to a bunch of rars to split the file size and moving them individually
1982sketcher -
Hey everyone, here's the very best way to PERFECTLY organize your screws AND keep track of the order of the procedure: Get a piece of plain corrugated cardboard and a pen (I like using a Sharpie). For EACH step of the disassembly, draw a simple diagram of the layout of the computer on the piece of cardboard, with dots or Xs where the screws are located. Right after you remove each screw from the computer, poke a hole in the cardboard in its corresponding diagram position with your screwdriver and place the screw in that hole. If there are other non-screw related parts to be removed, you can add notes below each step diagram to remind you of where they go or how they should be placed. This cardboard method is great not only because your screws will not go flying or get mixed up by accident if bumped, but each screw goes EXACTLY back where it came from and you can keep the cardboard as a template for future use if necessary!
- zerø K
zeroK - Replica
for all the mac 2011 owner. we should pressure apple to accept their fault. they gave as a piece of junk while they took our $2000. -betrayed apple fanboy
mindful - Replica
These instructions worked great for me. I ordered a replacement battery from Key Power (on Amazon) for my 15" Macbook Pro (mid-2010). Cost was $74 shipped.
Battery came with 3 different screwdrivers to help with installation. I just needed the one size though, since my 2010 seemed to use all the same size screws.
Thanks!
Marcos - Replica
During re-assembling (put the screws back in), it is important to note that the 3mm threaded holes are not completely vertical, but bent a little bit such that the hole direction is rectangular to the tapered surface. The force of the screwdriver must point towards the direction of the hole. Otherwise the screw gets jammed
kusi - Replica
There is a FOOLPROOF WAY TO ORGANIZE ALL SCREWS and other parts removed.
Print the repair guide.
Yes, the actual photo of the bottom of the laptop with the circles around the screws.
When you remove the screw, tape it to the photograph.
You will tape the screw to the exact location that you just removed it from.
Same thing with any part you remove.
splashzoneent - Replica
Thanks Splash!!! I used your suggested method, and it was perfect: kept all my screws, and i was able to, very easily, put them back in their correct place. I greatly appreciated your feedback. Thank you for sharing!!
Tommy Kedar -
Thank you!!! This worked fabulously - even the I.T. people at my workplace were excited as they never thought to do that before. Replacing the battery took about 10 minutes!
nclarke36 -
Worked like a charm! Took less than 20 minutes.
It's Oct. 2015, and the fan cost me about $10. it was the same brand/model...
SUNON MG62090V1-Q020-S99 .
SOME TRICKS -
1- no T6 screwdriver- was careful using needle nose players to loosen 2 screws protruding up, then use a small phillips to push real hard into the T6 slots, SLOWLY turn , also used a small flat head screwdriver (for eye glass repair) was able to grab thread on T6's, made a small mark with screw driver across the top so I could see when it started to turn.
2- no spudger -made one; cut a little strip 1/2" x 1 1/2" of plastic. couldn't get it to slide under plug, there's an edge where plug fits. so lifted old fan out, pulled upward on the plug it popped right out with very little effort. I used my home made spudger to push the new plug into place.
3- download free "Macs Fan Control" This is how I was alerted to the fan not working in the first place. Program shows temperature of all key components in the computer.
cheers- Durango CO!
Dgodrummer - Replica
Watch the video first, read the entire tutorial and all the comments before you start, and spread a white towel on the floor so you can find screws when you drop them. Watch this first -- http://www.youtube.com/watch?v=qiBxhA29e...
kevicoll409 - Replica
Please be aware that you CAN do this replacement with MUCH LESS work. I successfully replaced a trackpad (TP) in this model WITHOUT removing a lot of what is described here. I think i mainly removed the logic board (LB) anchor screws along the TP side and was then able to lever up the LB just enough to get the cable unplugged and snaked out. Followed the reverse and done. Maybe not for all, but it worked for me. // Re screws: i print out the images here of the multi-screws locations and then tape the screws in place on the print-out.
Danno - Replica
Is it necessary to ground oneself to prevent static damage to logic board, etc. when replacing the speakers?
If so, what is the best way to do this?
Do you wear wrist strap designed for this purpose? To what metal object do you attach the clip and wire? I’m assuming the aluminum case isn’t going to work.
Sibyl Smith - Replica
I will be buying a battery from you and using your instructions. I just installed a new CD/DVD using your instructions and 1) I feel like I owe you something and 2) Although more expensive, I have the confidence your battery will work. My current battery is the original with 1399 cycles in 7.2 yrs. A tech buddy had bought me a replacement and I installed it. I had just installed a new OS and the kernel_task went going nuts, using 90% of the CPU. Hours on the phone with Apple did not resolve the issue. On a whim, I put the old battery back in and Voila! But I cannot risk my battery swelling and going south on me. I am also going to buy your installation tools. Yeah, I already have them. But you can never have enough tools…or beer. And you don’t sell beer.
Pete Banks - Replica
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
After pulling out the lower case and put it back on, the lower case doesn't stick well with the left clip. What should i do now?
Januar Wiyogo - Replica
What is the maximum amount of RAM that can be installed in this MacBook?
michael - Replica
16 GB is the max
Bradon Kelley -
For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified. Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
nails work pretty well as well...
Sibe Jan Kramer - Replica
At first sight I was confused when I read the description at this step, 'cause it seemed that disconnecting the battery connector was optional, in order to eliminate static discharge. While it's a helpful advice in other circumstances (as mentioned as an example changing hard drives), when changing the battery it is not an option - you have to disconnect the battery connector.
It would have been better to mention the optional disconnecting recommendation in a side-note.
Other than that, an excellent guide!
Damienn - Replica
the fact that this step is optional can not be stressed enough. i tried disconnecting the battery and in the process it short circuited which now leaves me with an even more expensive problem than i had before when i just wanted to change hard drives (at least the new hard drive works fine..)
the hard drive changing worked though.
nina - Replica
Excellent guide, it was as easy as a breeze to replace my battery. I can't believe I nearly followed Apple in their saying that this part was not user replaceable. Great job for this description, and many thanks. iFixIt is THE reference for Mac owners.
Patrick.
Patrick Demaret - Replica
So - I have a weird comment about this. I wanted to make sure that I was getting the right model - so I opened up my laptop and then thought "well, why not just remove the battery while i'm in here, it's shot anyway". Though, I forgot about the stupid screws (Apple really did us over on that one!). Though I disconnected the battery connector and didn't bother to re-connect it when I was finished and just put the cover back on.
Here's the weird part - when I went to turn my laptop back on...MY BATTERY WAS RECOGNIZED...AND WORKING! I was under the impression that the connector "connects" the battery's charge to the laptop, but this just doesn't make sense! Plus, now my very dead battery is in "normal" condition according to the system report. I haven't worked for apple, but have about 5 years of IT experience and am baffled by this! I'm starting to think i've experience a miracle! Has this happened to anyone else?
Shelly - Replica
Possibly disconnecting the battery caused the System Management Controller to reset. That might have been your problem rather than the battery itself. See http://osxdaily.com/2010/03/24/when-and-...
Duke Briscoe -
I'd just like an advise of where to dispose the old battery. Thanks
Jaime Serafim - Replica
Any Best Buy or Batteries + Bulbs accepts batteries for recycling in their stores. Many other stores such as Home Depot do as well.
xtophr -
My battery won't work after reconnecting it, I made sure everything was done as stated, what can I do to fix this?
r1m111 - Replica
My battery connector pulled off parallel to the board surface
Mazo - Replica
I tried spudging the corner closer to the wires which was probably a bad idea. The corner broke off! I can't believe it was that brittle. So be careful. If it did it again, I'd aim for the corners AWAY from the wires or the sides themselves, though I seem to recall there not being much of a lip.
Dave Kitabjian - Replica
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Move battery removal step to this point in upper case replacement guide.
Paul Palm - Replica
Remove the following three screws securing the left fan  to the logic board:
  • Remove the following three screws securing the left fan to the logic board:
    • Two 3.5 mm T6 Torx screws.
    • One 4.2 mm T6 Torx screw.
Aggiungi Commento
Use the flat end of a spudger to disconnect the left fan connector from the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket.
  • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket.
    • The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Mine had all three screws the same length (3.5 mm I believe)
Rusty Simmons - Replica
Lift the left fan out of the upper case.
  • Lift the left fan out of the upper case.
Aggiungi Commento
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
  • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
Of course, this is not the right fan but the left in the picture.
maccentric - Replica
Managed to break off a fan connector. Really poor mistake there, as it really is not too hard. Follow exactly like the picture and realize that it lifts up! But good news, I managed to break one of the least important parts and the computer still runs fine!
Sam - Replica
Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board. Lift the right fan out of its opening in the logic board.
  • Remove the three 3.4 mm (3.1 mm) T6 Torx screws securing the right fan to the logic board.
  • Lift the right fan out of its opening in the logic board.
Aggiungi Commento
Pull the camera cable out of its socket on the logic board.
  • Pull the camera cable out of its socket on the logic board.
  • Don't lift upward on the camera cable as you disconnect it. Pulling upward on the cable may damage both the cable and the logic board. Pull the cable parallel to the face of the logic board.
One can see how to remove the cable in this picture: https://d3nevzfk7ii3be.cloudfront.net/ig...
Better than pull is to push it with something like a screwdrive at the small angle left and right.
Alex Nevell - Replica
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
  • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
Am I the only one but my MacBook has black shielding on the CD-R drive, not some clear tape stuff to reveal the internals on the drive….
Vincent Mahler - Replica
Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
  • Use the flat end of a spudger to lift the optical drive connector out of its socket on the logic board.
Mine had a little adhesive strip behind the connector. Pull gently
nicholasmcroberts - Replica
Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
  • Disconnect the hard drive/IR sensor cable from its socket on the logic board by lifting up from beneath its connector.
Aggiungi Commento
Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
  • Use the flat end of a spudger to lift the subwoofer/right speaker connector out of its socket on the logic board.
  • Pry up from beneath the wires.
Be really, really careful detaching this connector - make sure it's lifted from the cable side. I managed to remove the whole lot from the logic board by accident. On mine it was disguised under a lump of rubber foam.
To replace it, I removed the socket, held it in place against the solder pads and ran a 750degF soldering iron across the pads. It's definitely reattached it, I'm not sure how good the electrical contacts are yet.
afoster - Replica
There is foam on the top of this connector. Do not pry up from under that. Instead, put your spudger underneath the red and black wires themselves and pry up. Very little resistance.
Alex Grayson - Replica
Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board. Lift the cover off the logic board and set it aside.
  • Remove the two 1.5 mm ( 1.2 mm ) Phillips screws securing the keyboard/trackpad cable cover to the logic board.
  • Lift the cover off the logic board and set it aside.
Be sure to use the right size screwdriwer, as these screws might be hard to remove. I ended up having to cut the metal cover and bend it away as the screws wouldn't come loose.
That works too however..
dmitri - Replica
I ended up using a #000 phillips screwdriver instead of the #00. I was able to get this piece up without issue.
Dave Bruhn - Replica
I bought ph#00 screwdriver and it doesn't work for all phillips screws. Just buy #000 phillips screwdrive for all phillips screws.
ozhan - Replica
Can I get it work with PH#00?
Utsav Dusad - Replica
I was able to skip this step, along with 16, 17, & 18, and complete the repair successfully. Instead of fully removing the logic board as described in step 22, I lifted the left edge and then wiggled it left until I could lift it from the hinge edge; this gave me plenty of room to see what I was doing while removing and replacing the DC-in board.
Sarah Dunlap - Replica
@Sarah Dunlap. Yes, I did the same, it entirely possible ( although fiddly ) to complete this repair without fully removing the Logic board and instead lifting it out of the way taking care not to put too much tension on the keyboard ribbon cable.
bill borez - Replica
Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
  • Use the flat end of a spudger to pry the trackpad connector up and out of its socket on the logic board.
Aggiungi Commento
Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger to pull the keyboard ribbon cable out of its socket.
Need a better picture of the zif connector. You lift the lock from the side farthest from the flat cable, and it lifts toward the cable. When reinserting be sure to get the cable all the way or you may have only half the keyboard working.
Jim - Replica
Definitely should have read this comment before I cracked the ZIF socket…
Joshua Vande Walle -
I could use some advice on reinserting the ZIF cable firmly in its socket. I can get it started, but getting it far enough in to make contact is difficult, given its flexibility. Any tips on manipulating it?
CJ Attias - Replica
I used a piece of sticky tape that I attached to the ZIF cable, then pulled firmly on the tape (attached to the cable) to get the ZIF cable to seat properly. The tape held to the cable, the ZIF cable seated properly, and the keyboard worked.
robertemcgee -
getting the cable back in was leaps and bounds more difficult than this entire replacement job! be very very careful and note that it goes alllll the way in. i bent the ribbon like crazy, but the keyboard still seems to work fine!
shmianco - Replica
REINSERTING THIS CABLE WAS ABSOLUTELY THE MOST DIFFICULT STEP IN THIS WHOLE PROCESS!
Key points:
•Make sure that it's inserted evenly. It's tempting to get one edge in, and then the other, but that approach will prevent it from seating properly.
•The cable goes all the way in. There is maybe 1/16" of the little grooves showing, but not much more.
•Once the cable is properly seated, use a piece of tape to pull it all the way in, and keep the tension on the tape as you use a sprudger to flip down the retaining flap.
•It's a fragile connection, and if you break the cable it's a top-case or keyboard replacement, which is either expensive or a PITA, so patience is key.
Kyle - Replica
It's very easy to do this step incorrectly. Make sure to use your fingernail and pry gently. This was the only step I felt didn't have a great explanation and damaging the part could easily happen.
tgphotosales - Replica
I messed up and broke the connector. Here is part of a video showing in close-up how to remove it properly (different model Mac, same connector). Wish I had seen it before I tried it.
wizzart - Replica
Thank you for posting that video link. You saved me a lot of frustration!
disneyfunteacher -
Thanks for posting the video. Made it much clearer how to disconnect and save damage!
Gareth Aschenbrenner -
When they say "retaining flap", they are referring to a square plastic clip that hinges to the clip on the board. Starts at 7:15 in the video.
kevicoll409 -
Thanks a lot! Great video
Sean Kandel -
I needed that video. Thanks
Justin Brisotto -
Thank you to everyone who commented about this step. I did not have any trouble doing this but I could have. Also for all the excellent clarification especially the tips on reinserting the ribbon cable which I have yet to do after I hopefully fix the logic board
Peter Newman - Replica
When they say "pull" the cable, they mean to "slide" it. Do not lift and pull.
Attaching a small piece of tape and pulling parallel to motherboard did the trick.
Brian Blair - Replica
I had trouble getting the cable out (let alone back in!) In the end, sliding a toothpick in behind the ribbon and gently pulling from both sides of the toothpick did the trick.
Kal - Replica
On reassembly, I realise why it was so hard to get out—I had not lifted the retaining flap, thinking they just meant the flap of tape. Not well illustrated in the photo. The retaining flap is the long bit of plastic opposite the ribbon (closer to the fans).
Kal - Replica
I acquired a macbook pro with a cut trackpad wire and no battery. In looking at this layout my concern is… what if the connection is pulled from the hinge and the hinge to hold it into place is completely missing?
Anthony Eliseo - Replica
Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
  • Use the flat end of a spudger to lift the battery indicator connector up and out of its socket on the logic board.
Aggiungi Commento
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board.
  • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
  • Pull the display data cable straight out of its socket on the logic board.
  • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
The metallic flap controlled by the plastic handle looks like it could easily break... a safer route is to grab the shielded cable after rotating the metal flap out of socket and gently pry it out of the socket by applying force parallel to the logic board. It will probably take a few minutes but you could save yourself some gray hairs.
This is the hardest step IMO
brbulic - Replica
Indeed this s the hardest step.its not clear from the instruction that there are two elements to this component. The connector and also a metal retaining clip that needs to be rotated off the connector first.
mail - Replica
this was the hardest part of the dismantling for me. it's not super obvious in the pictures that there is a hinge and the metal piece, attached with tape, swings over and towards the DC-in.
shmianco - Replica
I found it easiest to grab the connector where the hinged metal piece connected to the body.
Replacing this connector was a bit fiddly, as you have to make sure it's lined up exactly before pushing it in, and because pushing it in requires a bit of force.
Kyle - Replica
"Pull the cable straight" means to slide the connector out, do not lift and pull. Also, check for a square locking clip attached to the plug, if it won't come out.
I really advise you to remove the cable retainer (one 8.6 phillips, you can see a photo in the display replacement tutorial) BEFORE unplugging the cable, to have more freedom of movement (to plug it in back it's even more important). Those are REALLY flimsy (i just broke one without being brutal and believe me you don't want to change it).
Bonachera - Replica
I found it helpful to remove the bracket for the display cable to allow more movement of the cable when attempting to reassemble
Justin Brisotto - Replica
Really great site!! replaced a LB in an mid 2010 MBP with kernal panic crash. Fixed! No issues with detailed procedure and comments. So I'll add one for this step. This was the simplest step really. Additional clues. (Wish I could post a pix). Look at the gold conn in the pix above. Note that the cable mates with the conn with the 2 tabs each side showing full insertion. The silver retainer pops up, bar away from the cable. Using my custom tool, a small screw driver, filed really small as I don't have a #000 Phillips, release the retainer, then carefully wedge open the tab on each side, inserting your "tool" in the slot. Neatly and slowly, the conn comes apart. Putting it back together, once the conn is alligned, just push alternately on each tab. Doesn't take much effort, better that pushing on the cable. I also appreciate the comment that removing the clamp, both clamps with one screw actually, makes this easier.
Bruce Rayner - Replica
This is indeed a tricky step. First time, after following all the steps and reassembling I had no screen, which freaked me out. Luckily, another go at the connector did the trick and now I’m a happy owner of a macbook with a new trackpad. Thanks!
Balazs Gobel - Replica
This step is really unclear! After grabbing what I thought was the “plastic pull tab” and having it come off in my hand, I was clueless about how to proceed. After puzzling over it for about 15 minutes, I saw the actual “plastic pull tab”, which was against the mother board near the fan. Pulling this upward unlocked the metal hinge and everything else was obvious after that.
xtophr - Replica
I agree, this step was unclear. Part of the problem may be variations between logic boards. Mine did not look like the one pictured here. Mine has a tab lying flat against the logic board, as also described by xtophr. If this describes yours, check out [|this video] https://m.youtube.com/watch?v=-IE3WNOsrZ... (around 40 seconds in) to see exactly how it comes out. You lift the locking clip up by the plastic tab, then (with a little bit of downward pressure on the cable) slide it out towards the nearest corner of the machine.
Kal - Replica
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket. Be sure you are flipping up the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
  • Be sure you are flipping up the hinged retaining flap, not the socket itself.
  • Pull the keyboard backlight ribbon cable out of its socket.
Connector slides out, do not lift and pull.
any replacement parts available for this? I pulled up instead of sliding cable :(
Allen Jenkins - Replica
This step would benefit from a macro view of hinged retaining flap and clarification. The instruction about flipping up the hinged retaining flap is misleading people into trying to flip out the ribbon.
Frank Wilson - Replica
Remove the following nine screws:
  • Remove the following nine screws:
    • Seven 3.4 mm ( 3.1 mm) T6 Torx screws on the logic board
    • Two 8 mm T6 Torx screws on the DC-In board
Remove T6 (smaller) screws first, that was the last screwdriver that you used (for smooth workflow).
Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal. If necessary, use the flat end of a spudger to separate the microphone from the upper case. Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
  • Carefully lift the logic board assembly from its left side and work it out of the upper case, minding the optical drive cable and the I/O ports that may get caught during removal.
  • If necessary, use the flat end of a spudger to separate the microphone from the upper case.
  • Pull the I/O port side of the logic board away from the side of the upper case and remove the logic board assembly.
I had a little difficulty pulling the motherboard before the battery. I'm not sure why you would want to do it in the order listed here, but doing steps 23 and 24 first helped the board come out easier.
The thing that caught me on this step was that, at least on mine, the speaker box was glued/taped to the case, and so I got rather nervous trying to remove the logic board as it wouldn't move until said adhesive was pried apart. Thank goodness I knew the difference between the sounds of "board breaking" and "adhesive separating", but this step was still rather harrowing for me.
Joseph Sikorski - Replica
The microphone cable was easy to pry off the logic board for disassembly. For re-assembly, I was having a heck of a time getting the connector to connect to the logic board. There just isn't enough room to get your hands and tools in there and still see what you're doing (unless you're a dentist and you're used to that kind of thing). Anyway, I finally got brave and pulled the round, rubberized microphone from the case. I connected the short cable to the logic board, set the microphone in the made-for-the-microphone housing on the logic board, hoping it would stick itself back to the case once the logic board was in position, and I was back in business. In this case, simply stating "reverse these steps for reassembly" wasn't very forthcoming.
robk64 - Replica
Pulling the microphone off the case is key to reassembling. Place the mic back into the cut-away in the speaker housing and plug the connection into the backside of the logic board
Justin Brisotto -
thx graciaaaas :)
driveremule -
When I did this step the microphone was REALLY STUCK to the upper case, it actually stayed stuck to it and disconnect "itself" from the mother board while I was lifting up everything.
Finally, there was no damage : I separated the microphone from the upper case while reassembling, then connected it back to the mother board and put it on its housing.
Greg - Replica
Count the number of connectors as you remove the board, so that when you put it back one does not get lost under the board and you can't figure out why it won't go in. You should do this.
If you laptop was getting hot when charging then be extra careful in this step because the foam pad under the logic board my have started to fuse to the casing. If the pad seems stuck then use a knife to gently pry it up.
Jereme Shaver - Replica
I wish I'd read the comment on the items being stuck to the surface below
Mazo - Replica
I have the same case with Joseph Sikorski - it's hard to pull out the mother board because the speaker is glued that I thought their are remaining screws that hook in to it. Better use flat spudger to pry the right side that is stuck when you pull the left upward first.
Auldz Buss - Replica
Repairing a friend’s laptop… I wonder if the “glue” between the speaker and case is actually juice or soda, lol
Sarah Ybarra - Replica
This part was highly stressful. The microphone/left speaker assembly are fused to the underside of the logic board. As you are facing the project according to the layout in these photos, the mike assembly is on the right side of the logic board, towards the top end. It is fused to the logic board but it also has adhesive sticking it to the upper case. As you lift, you have to insert a long spudger flat end down into that corner and move it back and forth between the mike assembly and the upper case, and it will release. Be very patient, focused, and slow. The spare part I bought from iFixIt had an extra speaker there in case I messed up, but I did not need it.
jruedas - Replica
Disconnect the DC-In board by pulling its cable toward the heat sink.
  • Disconnect the DC-In board by pulling its cable toward the heat sink.
  • Pull the cable parallel to the face of the logic board.
I was trying to unplug the cord of the mega safe card and I broke two components near to that in the logic board I think are fuse, but I really don´t know what are, any body knows what kind of components are? and if I get that components it is possible to weld it again to the logic board, the problems was when I plug the mega safe cord, the battery won´t charge, I think that two components its for make that working, any help, thank you all!!!
the two components are near to the thumb of the guy in the last picture step 23. thanks....
jpatinop - Replica
"Pull parallel" means to slide the connector out, do not lift and pull.
Use flat edge of spudger on the ack edge of the plug to slide the connector out.
Uh, this power entry module is not exactly the same as the OEM unit. it appears that the mounting hole on the side closest the keyboard is offset by about 1/8" - This isn't good. Any suggestions from the field on what to do next? Thanks, Chris
Chris Johnston - Replica
Conclusione
Altre 26 persone hanno completato questa guida.
Andrew Optimus Goldberg
Membro da: 17/10/2009
367.875 Reputazione
1.264 Guide realizzate
iFixit Membro di iFixit
Community
117 Membri
5.743 Guide realizzate
Dont want to double post so please refer to the guide for the display to see my issue, but folwed teh guide to the T. The only anomaly i found ater reseting everything again is darkish tint ont he display cable, the rest of hte story is on my post on guides for displa. any help guys will be greatly appreciated. I'll defintelyl guys you guys business from here on how, And yes i know i work or apple but his machine ha my bitcoins.and pgp keys. and i still love her.
mark Andrews - Replica
Good tutorial. New DC board installed and Macbook now charges without getting hot at all.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 130
Tutti i Tempi: 8,026
