Introduzione
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
Cosa ti serve
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to lift the AirPort/Bluetooth connector out of its socket on the logic board.
Altre 7 persone hanno completato questa guida.
