Salta al contenuto principale
MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement
Cosa ti serve
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement, Access Door: passo 1, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement, Access Door: passo 1, immagine 2 di 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 2, immagine 1 di 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement, Battery: passo 3, immagine 1 di 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement, Lower Case: passo 4, immagine 1 di 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 5, immagine 1 di 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement, Optical Drive: passo 6, immagine 1 di 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 7, immagine 1 di 1
    • Deroute the camera data cable from the channel in the optical drive.
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 8, immagine 1 di 1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  9. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 9, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 9, immagine 2 di 2
    • Remove two 8 mm Phillips screws securing the camera cable bracket to the upper case.
    • The rightmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out from the upper case.
  10. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 10, immagine 1 di 1
    • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 3.5 mm Phillips screw.
    • Two 2.5 mm Phillips screws.
  11. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 11, immagine 1 di 1
    • Lift the optical drive from its left edge and pull it out of the computer.
  12. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement, Subwoofer & Right Speaker: passo 12, immagine 1 di 1
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  13. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 13, immagine 1 di 1
    • Remove the following four screws securing the subwoofer and right speaker to the upper case:
    • Two 3.2 mm Phillips screws.
    • One 2.6 mm Phillips screw.
    • One 5 mm Phillips screw.
  14. MacBook Pro 15" Unibody Late 2008 and Early 2009 Subwoofer & Right Speaker Replacement: passo 14, immagine 1 di 1
    • Lift the subwoofer and right speaker assembly out of the upper case.
Conclusione
Altre 21 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 28
Tutti i Tempi: 27,695
