Salta al contenuto principale
MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement
Cosa ti serve
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Access Door: passo 1, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Access Door: passo 1, immagine 2 di 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 2, immagine 1 di 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Battery: passo 3, immagine 1 di 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Lower Case: passo 4, immagine 1 di 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 5, immagine 1 di 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Display Assembly: passo 6, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Display Assembly: passo 6, immagine 2 di 2
    • If necessary, peel the EMI gasket off the camera cable connector.
    • Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
    • Do not try to lift this connector straight up off the board. Pull the connector parallel to the face of the logic board.
    • Deroute the camera data cable from the channel in the optical drive.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 7, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 7, immagine 2 di 2
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
    • Seperate the camera cable bracket from the camera cable and remove it from the computer.
  8. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 8, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 8, immagine 2 di 2
    • Grab the plastic pull tab secured to the LVDS cable lock and rotate it toward the DC-in side of the computer.
    • Pull the LVDS connector straight away from its socket.
    • When disconnecting the LVDS cable, do not pull on the black tab secured to the LVDS cable lock. We recommend wiggling the cable while applying tension to slowly "walk" the connector out of its socket.
  9. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 9, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 9, immagine 2 di 2
    • Remove the 7 mm Phillips screw from the LVDS cable bracket.
    • This screw may remain captive in the LVDS cable.
    • Lift the LVDS cable bracket out of the upper case.
  10. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 10, immagine 1 di 1
    • Remove the two outer 6 mm Torx screws securing each side of the display to the upper case (four screws total).
  11. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 11, immagine 1 di 1
    • Open your MacBook Pro so the display is perpendicular to the upper case.
    • Place your opened MacBook Pro on a table as pictured.
    • While holding the display and upper case together with your other hand, remove the 6 mm Torx screw from the lower display bracket.
  12. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 12, immagine 1 di 1
    • Be sure to hold the display and upper case together with your other hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm Torx screw securing the display to the upper case.
  13. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 13, immagine 1 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 13, immagine 2 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 13, immagine 3 di 3
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
    • Lift the display away from the upper case, minding any brackets or cables that may get caught.
  14. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Front Display Glass: passo 14, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, Front Display Glass: passo 14, immagine 2 di 2
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
    • Before starting, be sure to clean the display glass with lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier
    • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
    • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
  15. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 15, immagine 1 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 15, immagine 2 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 15, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Compra
    • With the panel sufficiently heated, fasten a heavy-duty suction cup near the upper right corner of the display glass.
    • Don't fasten the suction cup on top of the rubber strip around the edge of the display glass.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • Slowly and gently pull the corner of the display glass up off the display assembly.
    • If only the top edge of the glass lifts up (as seen in the third picture), repeat steps one and two until you can lift up the corner of the panel.
  16. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 16, immagine 1 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 16, immagine 2 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 16, immagine 3 di 3
    • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
    • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
    • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  17. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 17, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 17, immagine 2 di 2
    • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
    • Attach a suction cup along the right side of the front glass panel.
    • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
    • Continue working along the right edge of the front display glass until it is separated from the display.
    • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
  18. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 18, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 18, immagine 2 di 2
    • Use your heat gun to soften the adhesive under the black strip along the top edge of the glass display panel.
    • Attach a suction cup near the top edge of the glass display panel and use it to pull the glass panel up off the display.
    • Work along the top edge of the glass panel, carefully using the flat end of a spudger to separate the adhesive if necessary.
  19. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 19, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 19, immagine 2 di 2
    • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
    • Attach a suction cup near the upper left corner of the glass display panel.
    • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
    • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
  20. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 20, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 20, immagine 2 di 2
    • Use a heat gun to soften the adhesive under the black strip along the left side of the front glass panel.
    • Attach a suction cup along the left side of the front glass panel.
    • Continue working along the left edge of the front display glass until it is separated from the display.
  21. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 21, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 21, immagine 2 di 2
    • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
    • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
    • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
  22. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 22, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 22, immagine 2 di 2
    • Insert the edge of a plastic opening tool between the display glass and the camera bracket, and run it around the camera bracket to separate it from the display glass.
    • Do not forget to stick the camera bracket down to the new front display glass before reassembly.
  23. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 23, immagine 1 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 23, immagine 2 di 3 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 23, immagine 3 di 3
    • During the glass removal process, the camera cable may stick to the adhesive on the glass panel, disconnecting it from the camera board as the panel is lifted. If your camera cable is still connected to the camera board, skip this step.
    • To reconnect the cable, first use the tip of a spudger to remove the piece of foam tape over the camera cable ZIF socket.
    • Use the tip of a spudger to flip up the ZIF cable retainer on the camera cable socket.
    • Insert the camera cable into its socket on the camera board and use the tip of a spudger to snap down the ZIF cable retainer, locking the cable in place.
    • Reapply the piece of tape covering the camera cable socket.
  24. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, LCD: passo 24, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement, LCD: passo 24, immagine 2 di 2
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
  25. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 25, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 25, immagine 2 di 2
    • Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
  26. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 26, immagine 1 di 1
    • Remove the six 2.9 mm Phillips screws securing the LCD panel to the front bezel.
  27. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 27, immagine 1 di 1
    • Pull the LCD toward the top edge of the display to slide the circuitry along its lower edge out of the recess in the aluminum display assembly.
    • It may be helpful to use one hand to feed the display data cable through its channel in the aluminum display assembly as you pull the LCD toward the top edge of the display with the other hand.
  28. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 28, immagine 1 di 1
    • Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
  29. MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 29, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 LCD Replacement: passo 29, immagine 2 di 2
    • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
    • Pull the display data cable straight away from its socket on the LCD.
    • Lift the LCD out of the display assembly and set it aside.
    • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
Conclusione
Altre 53 persone hanno completato questa guida.
6 Commenti
Amazing and wonderful. With a hairdryer, a loving wife who knows how to clean glass much much better than I do, the tools listed here and some patience, I now have a wonderfully ugraded 2008 unibody MBP with a high resolution display (wasn't offered until 2009). My display issues are gone as indeed my vertical banding was caused by a broken display.
jon845 - Replica
Does one have to buy the LVDS display cable or can the one that is in the macbook already, be used?
Jelle Hanssens - Replica
I'm by no means an expert, or even vaguely knowledgable :), but i would assume you can just use the old cable, if it's just the actual LCD itself that is damaged and the cable seems fine.
Mal -
Great guide, i thought it was going to be tricky, but following this made it easy! I was actually replacing the display rear panel and the glass - my LCD was fine - so i had to improvise slightly taking hinges etc from damaged panel, but this guide made everything seem pretty straightforward, thanks guys!
Mal - Replica
THANK YOU THANK YOU THANK YOU for saving me from a $600 Apple Store repair bill! The instructions were excellent and I felt very comfortable working my way through the repair.
I lucked out getting the glass off. I heated the upper right corner until it was warm to the touch, attached the suction cup and... pop. The glass came off instantly in one piece. Unfortunately, I broke it trying to get the camera bracket off, but it looked like shite after being knocked around for seven years and I was planning on replacing it anyway. I also replaced the LVDS cable along with the LCD and bezel. The display looks as good as the day I took it home from the Apple Store back in 2008.
I'm giddy that I have my laptop back. Tablets are all the rage nowadays, but they really do have their limitations. You need a proper keyboard to do any serious work.
Thanks tons for putting out these repair guides and the great tools.
LawGeekBC - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 40
Tutti i Tempi: 88,806
