Introduzione
Is the right side of your MacBook Pro mute? Use this guide to replace the subwoofer & right speaker assembly.
Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
Aggiungi Commento
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Aggiungi Commento
  • Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
  • If you don't have a Pentalobe driver, a 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head.
  • If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
  • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However, it is recommended to remove all power sources from electronics before working on them.
It really depends on how thick the 1.5 mm flathead screwdriver is. I tried a low-cost tool and almost destroyed the screw. So be carefull
Paul - Replica
Unfortunately, when I added a second hard drive via these instructions, all went well but Bluetooth is now MIA. Can anyone help?
Peter Payne - Replica
I agree...
I have bought a used MacBook Pro, when problems arise, opening Corps was trying to turn the screw, but with poor quality could not turn a screwdriver, only to ruin the screw. Try to buy ifixit Screwdriver set. Good luck to all and thank you ifixit team for such assistance as ifixit.com. Thank you.
remjok - Replica
Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
  • Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
The screws holding my battery were all worn out since an earlier removal. So instead of ruining them even more I put some saran wrap on the tip of my pentalobe driver and gently unscrewed them.
magnus - Replica
I have a problem with these screw. They a completly warn and I need some new ones to fix the new Battery.
Does anyone know which thread it is and which length?
alexanderleith - Replica
Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
  • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
Aggiungi Commento
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case. Do not try to completely remove the battery just yet.
  • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
  • Do not try to completely remove the battery just yet.
Aggiungi Commento
Tilt the battery back enough to access the battery cable connector.
  • Tilt the battery back enough to access the battery cable connector.
  • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Aggiungi Commento
Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
  • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
  • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
I tried to move the plastic piece, but it seemed risky for someone with no experience like me. It was not hard at all to just peel off the camera cable without messing with the connector, and then, carefully take the optical drive out.
joaquingoyret - Replica
Disconnect the camera cable by pulling the male end straight away from its socket.
  • Disconnect the camera cable by pulling the male end straight away from its socket.
  • Pull the connector parallel to the face of the logic board, not straight up.
Aggiungi Commento
Peel the camera cable off the adhesive securing it to the optical drive.
  • Peel the camera cable off the adhesive securing it to the optical drive.
Aggiungi Commento
This step is only required if you have an anti-glare display. If you have a glossy display, skip this step. Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
  • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
Aggiungi Commento
This step is only required if you have an anti-glare display. Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Lift the Bluetooth board/cable retainer assembly out of the upper case.
Aggiungi Commento
Use a spudger to pry the optical drive connector straight up off the logic board.
  • Use a spudger to pry the optical drive connector straight up off the logic board.
Aggiungi Commento
Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
  • Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
Aggiungi Commento
Lift the optical drive from its left edge and pull it out of the computer. When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
  • Lift the optical drive from its left edge and pull it out of the computer.
  • When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
Aggiungi Commento
Débranchez le connecteur du câble du lecteur optique de celui-ci.
  • Débranchez le connecteur du câble du lecteur optique de celui-ci.
Aggiungi Commento
Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board. Peel the hard drive cable up from the channel within the subwoofer and right speaker.
  • Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
  • Peel the hard drive cable up from the channel within the subwoofer and right speaker.
Aggiungi Commento
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
i pried from the wrong side and broke the connector. :( is there any way to fix this? I lost 60 percent of my sound. AND THE SUB!!! D:
Dustin Hoeppner - Replica
Remove the following four screws securing the subwoofer and right speaker to the upper case:
  • Remove the following four screws securing the subwoofer and right speaker to the upper case:
    • Two 3.2 mm Phillips screws.
    • One 2.6 mm Phillips screw.
    • One 5 mm Phillips screw.
Aggiungi Commento
Lift the subwoofer and right speaker assembly out of the upper case.
  • Lift the subwoofer and right speaker assembly out of the upper case.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 7,587
