Salta al contenuto principale
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement
Cosa ti serve
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement, Lower Case: passo 1, immagine 1 di 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 2, immagine 1 di 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement, Battery: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
    $5.49
    Compra
    • Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
    • If you don't have a Pentalobe driver, a 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head.
    • If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
    • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However, it is recommended to remove all power sources from electronics before working on them.
  4. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 4, immagine 1 di 1
    • Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
  5. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 5, immagine 1 di 1
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
  6. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 6, immagine 1 di 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 6, immagine 2 di 2
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  7. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 7, immagine 1 di 1
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it as soon as possible.
  8. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement, Hard Drive: passo 8, immagine 1 di 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement, Hard Drive: passo 8, immagine 2 di 2
    • Remove two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
    • Lift the the retaining bracket out of the upper case.
  9. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 9, immagine 1 di 1
    • Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
  10. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 10, immagine 1 di 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 10, immagine 2 di 2
    • Remove the hard drive cable by pulling its connector straight away from the hard drive.
  11. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement, Hard Drive/IR Sensor Cable: passo 11, immagine 1 di 1
    • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
    • Two 1.5 mm Phillips screws.
    • Two 4 mm Phillips screws.
  12. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 12, immagine 1 di 2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 12, immagine 2 di 2
    • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
    • Carefully peel the hard drive and IR sensor cable from the upper case.
  13. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 13, immagine 1 di 1
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
    • Lift the hard drive and IR sensor assembly out of the upper case.
  14. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 14, immagine 1 di 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 14, immagine 2 di 3 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Hard Drive/IR Sensor Cable Replacement: passo 14, immagine 3 di 3
    • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
    • Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
    • Gently pull the sensor bracket cable out of the ZIF connector.
    • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
    • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
Conclusione
Altre 54 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 20,222
