Introduzione
Use this guide to replace the logic board.
Cosa ti serve
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges.
Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
Remove the I/O Board cable from the MacBook Pro.
Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
Peel back the tape covering the top of the keyboard ribbon cable connector.
Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Use the flat end of a spudger to push the keyboard ribbon cable out of its socket.
Remove the four 3.5 mm T5 screws securing the heat sink to the logic board.
Grip both ends of the heat sink and lift it up from the logic board.
Use the tip of a spudger to flip up the metal retaining flap on the HDMI data transfer cable.
Gently pull the HDMI data transfer cable straight out of its socket on the logic board.
Altre 40 persone hanno completato questa guida.
10 Commenti
There's lots of mentioning of pulling and prying things out of sockets. Do they connect back on easily or require adhesive or anything? Could the logic board be reinstalled without any extra tools (keeping CPU in)?
Excellent tutorial, I completed it with ease. I'd recommend this to anyone looking to remove the logic board in a methodical manner. Thank you so much!!
When replacing the logic board it is actually not neccessary to disconnect the WiFi antenna connectors from the board. It is far easier to leave the very small and fragile connectors in place, as you are required to remove the entire WiFi board and install it on the new logic board anyway. This saves you the fear of breaking off RF connectors.
Ok, so I decided to clean the fans of my out of warranty MacBook Pro mid 2014 15". Before doing anything (like disassembling the fans) I disconnected the battery connector and started the cleaning (with a very soft brush). I accidentally misplaced the screws on the left fan by putting 4.4 mm T5 Torx screw in place of the 3.9 mm T5 Wide Head Torx screw. Now the mac looks dead. No light on the magsafe, no power on no nothing.
Does anyone know if the threads for the screw go all the way out of the motherboard or i just destroyed some layer of the motherboard ?
Please let me know ANYONE i'm desperate!
Hey! Same thing happened to me. Were you able to figure what happened?
