Salta al contenuto principale
MacBook Pro 15" Retina Display Mid 2012 Feet Replacement
Cosa ti serve
  1. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 2, immagine 1 di 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement, Feet: passo 3, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2012 Feet Replacement, Feet: passo 3, immagine 2 di 2
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
    • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 4, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 4, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Remove any broken or damaged feet.
    • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  5. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 5, immagine 1 di 1
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  6. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 6, immagine 1 di 1
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
    Chiedi a FixBot
    Aggiungi Commento
  7. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 7, immagine 1 di 1
    • Peel a replacement foot from the plastic backing.
    • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
    Chiedi a FixBot
    Aggiungi Commento
  8. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 8, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 8, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 8, immagine 3 di 3
    • Align the new foot inside the cavity.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • You may want to use a pencil to lightly mark where the alignment nub is located. Be careful not to scratch the lower case with your pencil.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
    Chiedi a FixBot
    Aggiungi Commento
  9. MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 9, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2012 Feet Replacement: passo 9, immagine 2 di 2
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 19 persone hanno completato questa guida.
Taylor Dixon
Membro da: 06/26/18
72.558 Reputazione
94 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 18
Ultimi 30 giorni: 118
Tutti i Tempi: 10,112
