Salta al contenuto principale
MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement
Cosa ti serve
  1. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement, RAM Shield: passo 2, immagine 1 di 1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 3, immagine 1 di 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement, Upper Case: passo 4, immagine 1 di 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 5, immagine 1 di 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 6, immagine 1 di 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 7, immagine 1 di 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 8, immagine 1 di 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 9, immagine 1 di 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 10, immagine 1 di 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement, Optical Drive: passo 11, immagine 1 di 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  12. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 12, immagine 1 di 1
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
  13. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 13, immagine 1 di 1
    • Lift the optical drive up and out of the computer.
  14. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement, PRAM Battery: passo 14, immagine 1 di 1
    • Disconnect the PRAM battery cable from the bottom right corner of the logic board.
  15. MacBook Pro 15" Core 2 Duo Model A1211 PRAM Battery Replacement: passo 15, immagine 1 di 1
    • Use a spudger to pry up the PRAM battery from the lower case.
    • Lift the PRAM battery out of the computer.
Conclusione
Altre 8 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
Un commento
Great Guide! Thanks! Got the weakened BIOS/PRAM changed, without having to touch the m/b at all, very fine!
Pertti Vanhatalo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 25,557
