Salta al contenuto principale
MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement
Cosa ti serve
  1. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Remove the lower case screws: passo 1, immagine 1 di 1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Lift the lower case away: passo 2, immagine 1 di 1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Battery: passo 3, immagine 1 di 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Fan: passo 4, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Fan: passo 4, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Fan: passo 4, immagine 3 di 3
    • Use a spudger to pry the fan connector out of its seat, and straight up off the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  5. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 5, immagine 1 di 1
    • Remove the following three screws securing the fan to the upper case:
    • One 6.5 mm Phillips.
    • One 5.5 mm Phillips.
    • One 4.5 mm Phillips.
  6. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 6, immagine 1 di 1
    • Lift the fan out of the upper case.
  7. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Logic Board: passo 7, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Logic Board: passo 7, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Logic Board: passo 7, immagine 3 di 3
    • Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
  8. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 8, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 8, immagine 2 di 2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips.
    • One 5 mm Phillips.
    • Lift the display data cable bracket out of the upper case.
  9. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 9, immagine 1 di 1
    • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
  10. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 10, immagine 1 di 1
    • In this step you will disconnect the camera cable. Most machines will have a small self adhesive plastic retainer stuck to the logic board to keep the connector in place. Before disconnecting the cable, be sure this retainer is moved out of the way.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  11. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 11, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 11, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to pry the optical drive, hard drive, and trackpad cable connectors up off the logic board.
  12. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 12, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 12, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 12, immagine 3 di 3
    • Use your fingernail or the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard ribbon cable.
    • Use your spudger to slide the keyboard ribbon cable out of its socket.
  13. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 13, immagine 1 di 1
    • Peel the small strip of black tape off the keyboard backlight ribbon cable socket.
  14. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 14, immagine 1 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 14, immagine 2 di 3 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 14, immagine 3 di 3
    • Use the tip of a spudger to flip up the cable retaining flap on the ZIF socket for the keyboard backlight ribbon cable.
    • Use your spudger to slide the keyboard backlight ribbon cable out of its socket.
  15. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 15, immagine 1 di 1
    • Use the flat end of a spudger to pry the battery indicator cable connector up off the logic board.
  16. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 16, immagine 1 di 1
    • Use the tip of a spudger to pry the microphone off the adhesive attaching it to the upper case.
  17. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 17, immagine 1 di 1
    • Remove the following screws:
    • Five 3.1 mm Phillips.
    • Two 3.9 mm Phillips.
    • Two 7 mm Phillips from the DC-in board.
  18. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 18, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 18, immagine 2 di 2
    • Remove the following Tri-point screws securing the battery to the upper case:
    • One 5.5 mm Tri-point screw.
    • One 13.5 mm Tri-point screw.
    • Lift the battery out of the upper case.
  19. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 19, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 19, immagine 2 di 2
    • Lift the logic board from its left edge and raise it until the ports clear the side of the upper case.
    • Pull the logic board away from the side of the upper case and remove it, minding the DC-in board that may get caught.
    • Be careful not to rip out the fragile connector plug of the microphone assembly.
  20. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement, Heat Sink: passo 20, immagine 1 di 1
    • Remove the four 8.5 mm Phillips screws securing the heat sink to the logic board.
    • A spring is held under each of these screws. Be careful not to lose it.
  21. MacBook Pro 13" Unibody Mid 2009 Heat Sink Replacement: passo 21, immagine 1 di 1
    • Gently lift the heat sink off the logic board.
    • When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
Conclusione
Altre 54 persone hanno completato questa guida.
4 Commenti
After completing this process and reapplying thermal paste on my CPU and GPU, CPU Core 1 & 2 temperature sensors were not being read. As a result, my fan was not operating and the CPU diode temperature jumped to >100C.
To fix this I had to reset the SMC (System Management Controller). For this model it is done by holding done Shift+Control+Option and pressing the power button while the computer is off.
I have OS X 10.8.5 running. I also replaced my battery at the same time as reapplying thermal paste. No idea if that affected the temperature sensors.
Tyler Ogden - Replica
Followed this guide to change thermal paste on CPU & GPU, all worked fine, now I have >10°C difference. I had a problem on a screw that wore out, solved by cutting a piece of motherboard. I recommend following this guide alongside a youtube guide video, if you are not sure on how to unplug some cables (like in which direction to pull). And as always, double (triple possibly) check that you have reconnected all cables, otherwise you’ll have to go through all of this again.
Pietro Spadaccino - Replica
Well, my computer no longer turns on...reconnected all the cables, was very cautious and followed all steps and now it won't power on...it will charge, just won't power on anymore
Jarvis Karchewski - Replica
me 2 Jarvis.any luck?
TheDoit123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 132
Tutti i Tempi: 59,498
