Introduzione
Use this guide to replace the logic board.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Remove the following screws securing the heat sink to the logic board assembly:
One 2.4 mm Phillips #00 screw
One 3.4 mm T5 Torx screw
Four 2.7 mm T5 Torx screws
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
Pull the right fan ribbon cable straight out of its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Gently push the edges of the MagSafe cable connector away from its socket on the logic board.
Altre 32 persone hanno completato questa guida.
Un commento
NOTE: The logic boards you are placing into your Macbook Pro as a replacement probably are not coming from systems that are current and actively being used (they may have been on the shelf for a while)…more importantly they are almost certainly not coming from systems that were fully updated and running MacOS High Sierra. Realize that if you have updated your Macbook and are running High Sierra, your hard drive has been converted to the latest APFS Apple file system. In order for an older logic board to be able to read any of your APFS hard drive will require that the logic board gets the latest SMC/firmware updates. Without this you will not be able to boot from your hard drive. See how I was able to correct this dilemma here: Hard Drive/OS not recognized after logic board replacement
