Salta al contenuto principale
MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement
Cosa ti serve
  1. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 3, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 3, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 3, immagine 3 di 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Battery Connector: passo 4, immagine 1 di 1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 6, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 6, immagine 2 di 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 7, immagine 1 di 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 8, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 8, immagine 2 di 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Battery Contact Board: passo 9, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Battery Contact Board: passo 9, immagine 2 di 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Left Speaker: passo 10, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Left Speaker: passo 10, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement, Left Speaker: passo 10, immagine 3 di 3
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
  11. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 11, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 11, immagine 2 di 2
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
  12. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 12, immagine 1 di 1
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
  13. MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 13, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Left Speaker Replacement: passo 13, immagine 2 di 2
    • Lift and remove the left speaker out of the upper case.
Conclusione
Altre 7 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.777 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 8,334
