    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
  • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
Aggiungi Commento
Wedge your fingers between the upper case and the lower case.
  • Wedge your fingers between the upper case and the lower case.
  • Gently pull the lower case away from the upper case.
Aggiungi Commento
The lower case is connected to the upper case at the center, with two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  • The lower case is connected to the upper case at the center, with two plastic clips.
  • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
Aggiungi Commento
Remove the plastic cover adhered to the battery contact board.
  • Remove the plastic cover adhered to the battery contact board.
This plastic cover wasn’t included with the new battery so I placed the original one back in. Was it supposed to go back in? This detail wasn’t clear since the original cover didn’t fit exactly over the newer battery connector. Plus any stickiness of adhesive that may have been there was gone.
arnolfo santoro - Replica
Remove the following screws securing the battery connector board to the logic board:
  • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
Top screw in this image was not a T6. I found that a T5 bit fit this one.
Alex Grayson - Replica
Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
Is adhered to screw beneath, so lift firmly and slowly.
Andrew - Replica
Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
I lost this screw! How important is it? Will it be okay with just the 3 previously removed screws?
Gerardo Jimenez - Replica
Carefully lift the battery connector board up off the logic board. It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
  • Carefully lift the battery connector board up off the logic board.
  • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
  • Do not fold the board completely over, or crease the cables, as this may damage the battery.
Aggiungi Commento
Grasp the Interposer with tweezers. An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
  • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
  • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
WHy to remove battery contact board? Replace can happen without it also, right.
Behram Beldagli - Replica
You don’t want to work on a live system as you could damage parts
Dan -
How can I remove interposer I m not able to remove it
Raunak - Replica
Remove the following screws securing the heat sink to the logic board assembly:
  • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
Hi,
found 4 rubber spacers on the 4 2,5mm screws
ddagonetroppo - Replica
Also found the rubber caps on the 4x2.7mm - didn't bother to replace the caps and didn't have any problems with them.
Rand Bell - Replica
  • Lift and remove the heat sink up off the logic board assembly.
  • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
Aggiungi Commento
Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
Aggiungi Commento
Remove the three 3.1 mm T5 Torx screws securing the left fan to the logic board assembly.
  • Remove the three 3.1 mm T5 Torx screws securing the left fan to the logic board assembly.
Aggiungi Commento
Lift and remove the left fan out of the upper case. Make sure to pull the left fan straight away to simultaneously pull the left fan ribbon cable out of its socket on the logic board.
  • Lift and remove the left fan out of the upper case.
  • Make sure to pull the left fan straight away to simultaneously pull the left fan ribbon cable out of its socket on the logic board.
Aggiungi Commento
Conclusione
Sam Lionheart
Membro da: 18/10/2012
323.981 Reputazione
1.664 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
6.010 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,275
