Introduzione
Use this guide to replace the upper case.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
Remove the gasket from the corner nearest display cable connector.
Peel up the six cable loops securing the antenna cables to the upper case.
Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
Remove the right speaker from the upper case.
Push/lift the keyboard ribbon cable off of the upper case with one hand.
With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
Once the retaining flap has been flipped up, carefully pull the ribbon cable straight out of its socket.
Altre 21 persone hanno completato questa guida.
