Salta al contenuto principale
MacBook Air 11" Mid 2012 Fan Replacement
Cosa ti serve
  1. MacBook Air 11" Mid 2012 Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Air 11" Mid 2012 Fan Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Air 11" Mid 2012 Fan Replacement, Battery: passo 3, immagine 1 di 2 MacBook Air 11" Mid 2012 Fan Replacement, Battery: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Air 11" Mid 2012 Fan Replacement, Solid-State Drive: passo 4, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  5. MacBook Air 11" Mid 2012 Fan Replacement: passo 5, immagine 1 di 2 MacBook Air 11" Mid 2012 Fan Replacement: passo 5, immagine 2 di 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    Chiedi a FixBot
    Aggiungi Commento
  6. MacBook Air 11" Mid 2012 Fan Replacement, I/O Board Cable: passo 6, immagine 1 di 1
    • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
    Chiedi a FixBot
    Aggiungi Commento
  7. MacBook Air 11" Mid 2012 Fan Replacement: passo 7, immagine 1 di 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    Chiedi a FixBot
    Aggiungi Commento
  8. MacBook Air 11" Mid 2012 Fan Replacement: passo 8, immagine 1 di 2 MacBook Air 11" Mid 2012 Fan Replacement: passo 8, immagine 2 di 2
    • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
    • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
    • Remove the I/O board cable.
    Chiedi a FixBot
    Aggiungi Commento
  9. MacBook Air 11" Mid 2012 Fan Replacement, Fan: passo 9, immagine 1 di 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    Chiedi a FixBot
    Aggiungi Commento
  10. MacBook Air 11" Mid 2012 Fan Replacement: passo 10, immagine 1 di 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
    Chiedi a FixBot
    Aggiungi Commento
  11. MacBook Air 11" Mid 2012 Fan Replacement: passo 11, immagine 1 di 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 25 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
122 Membri
25.946 guide realizzate
2Commenti sulla guida
I think my fan makes some noises when my laptop is cold in the morning... Cold means 18°C... Is it dangerous?
After a few minutes or even seconds, the sound stops.
Philippe Morin - Rispondi Condividi
I’m a 21 y/o college student whose laptop fan was being too loud to use in class and I decided to take matters into my own hands so I took the risk of completing these replacement instructions and I’m so glad I did! My laptop fan no longer makes noise and I didn’t have to take it to Apple and have them overcharge me for something simple enough for me to do at home. Thank you!!
Mariana Carbajal - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 21
Ultimi 30 giorni: 76
Tutti i Tempi: 10,997
