Salta al contenuto principale
MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement
Cosa ti serve
  1. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, Battery: passo 3, immagine 1 di 2 MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, Battery: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Card: passo 4, immagine 1 di 2 MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Card: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement: passo 5, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 11" Mid 2012 AirPort/Bluetooth Board Replacement: passo 6, immagine 1 di 1
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth board from the Air.
Conclusione
Altre 12 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
135 Membri
17.146 Guide realizzate
Un commento
Is that a mini pcie cable that is used for the networking card? I just am wondering if it is possible to disconnect the airport card and install a egpu there
Todd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 32
Tutti i Tempi: 8,654
