Introduzione
Use this guide to replace your MacBook Air's upper case. The upper case includes the keyboard and trackpad.
  • Shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
When you say:
Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
Nerdily yours,
Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
larryleveen - Replica
The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
Michael Welham -
I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
Allen - Replica
The magnetic mat is
GERARD SZAREK -
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Aggiungi Commento
In this step you will disconnect the battery to help avoid shorting out any components during service. Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • In this step you will disconnect the battery to help avoid shorting out any components during service.
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
My macbook air's configuration (Mid-2011 core i5) has a different battery connector. It slides into a receptacle on the logic board. If your battery connector does not look like the one pictured, use the pointy end of a spudger to depress the small indentation in the middle of the battery connector cable terminal, and pull aft to release the clasp mechanism.
Ethan Cross - Replica
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Aggiungi Commento
Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand. Do not lift the end of the SSD excessively.
  • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
  • Do not lift the end of the SSD excessively.
  • Pull the drive straight out of its socket and remove it from the logic board.
  • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
When you've completed all these steps to replace your SSD, don't despair if the MacBook Air shows a flashing folder with a question mark when you first power up the MacBook Air.
- Power off the machine, then keep the option key (= Alt key) pressed down, power on the machine again, and keep the option key pressed down until a prompt appears.
- If you've set a firmware password, then type it in at the prompt
- You should now be prompted for a hard drive to boot from. Select "EFI Boot"
- The MacBook Air should now boot to a window showing "OS X Utilities"
- Click on the  at the top left, then select "Startup Disk..."
- Select your SDD/Hard drive, and restart.
Michael Welham - Replica
When replacing the SSD, be careful about the connector orientation. Replacement boards look almost the same if they are upside-down. Note that the connector is not reversible - there is a notch that will only line up if the board is right-side up. If it doesn't seem to line up, flip the board over.
shamino - Replica
can i ask some links for some ssd’s that are compatible with that macbook model ?
giannismistil - Replica
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
  • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Aggiungi Commento
Peel the I/O board cable up from the adhesive securing it to the fan.
  • Peel the I/O board cable up from the adhesive securing it to the fan.
Aggiungi Commento
Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
  • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
  • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
  • Remove the I/O board cable.
Aggiungi Commento
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
  • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
Aggiungi Commento
Remove the following three screws securing the fan to the upper case:
  • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
Aggiungi Commento
Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
The replacement fan's ribbon cable is a few mm longer than the original. I t will loop upwards a bit after mounting. The rubber lip on top of the old fan needs to be transferred to the new fan.
Martin Heinrich - Replica
Remove the following five screws securing the battery to the upper case:
  • Remove the following five screws securing the battery to the upper case:
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Aggiungi Commento
Do not touch or squeeze the six lithium polymer cells when handling the battery.
  • Do not touch or squeeze the six lithium polymer cells when handling the battery.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Aggiungi Commento
Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case. Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
  • Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
  • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
Aggiungi Commento
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
  • Pull the keyboard backlight ribbon cable out of its socket.
Aggiungi Commento
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
  • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
Aggiungi Commento
Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
  • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
Aggiungi Commento
Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
  • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
  • Pry up from beneath the cables.
Aggiungi Commento
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket. Remove the small rubber gasket from the corner of the upper case near the display data cable. Remove the small rubber gasket from the corner of the upper case near the display data cable.
  • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
  • Remove the small rubber gasket from the corner of the upper case near the display data cable.
Aggiungi Commento
While holding the lock away from the socket, gently pull the display data cable out of its socket.
  • While holding the lock away from the socket, gently pull the display data cable out of its socket.
  • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
Aggiungi Commento
Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card. Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
  • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
Aggiungi Commento
Gently de-route the antenna cables from the slot cut into the logic board.
  • Gently de-route the antenna cables from the slot cut into the logic board.
Aggiungi Commento
Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
  • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
Aggiungi Commento
Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
  • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
Aggiungi Commento
Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
Aggiungi Commento
Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket. Be sure you are prying up on the retaining flap, not the socket itself.
  • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
  • Be sure you are prying up on the retaining flap, not the socket itself.
  • Pull the microphone ribbon cable straight out of its socket.
Aggiungi Commento
De-route the left speaker cable from the notch cut into the I/O board. Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
  • De-route the left speaker cable from the notch cut into the I/O board.
  • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
  • Pry up from beneath the wires.
Aggiungi Commento
Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
  • Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
  • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
Aggiungi Commento
Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
Aggiungi Commento
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
  • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Aggiungi Commento
Peel up the six cable loops securing the antenna cables to the upper case. Gently pull the cable loops slightly out of the channel cut into the upper case one at a time. Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Peel up the six cable loops securing the antenna cables to the upper case.
  • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
  • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
  • Repeat this for all of the retaining loops.
The plastic loops stay with the bottom and the wires go with the top (screen).
Dennis Fennell - Replica
Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total). Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
  • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
These screws are extremely tight, but they'll go!
Michael Sweetser - Replica
Open the display until it is perpendicular to the upper case and place it on a table as shown.
  • Open the display until it is perpendicular to the upper case and place it on a table as shown.
  • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
Aggiungi Commento
Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
  • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
  • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
Aggiungi Commento
Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly. Once the two display hinges have cleared the upper case, remove the display and set it aside.
  • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
  • Once the two display hinges have cleared the upper case, remove the display and set it aside.
Aggiungi Commento
Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case. Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
  • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
  • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
  • Remove the right speaker from the upper case.
Aggiungi Commento
Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case. Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
  • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
  • Remove the left speaker from the upper case.
Aggiungi Commento
Use the tip of a spudger to pry the microphone away from the side of the upper case. Remove the microphone from the upper case.
  • Use the tip of a spudger to pry the microphone away from the side of the upper case.
  • Remove the microphone from the upper case.
  • Upper case remains.
Aggiungi Commento
The ZIF connector for the keyboard ribbon cable is hidden under the cable itself. Push/lift the keyboard ribbon cable off of the upper case with one hand. With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
  • The ZIF connector for the keyboard ribbon cable is hidden under the cable itself.
  • Push/lift the keyboard ribbon cable off of the upper case with one hand.
  • With the other hand, use a spudger to flip up the retaining flap on the ZIF connector.
  • Once the retaining flap has been flipped up, carefully pull the ribbon cable straight out of its socket.
Aggiungi Commento
Use the flat end of a spudger to separate the trackpad ribbon cable from the underside of the keyboard. The cable is held in place with adhesive. Work carefully, and be sure to not let the spudger slip and damage any components.
  • Use the flat end of a spudger to separate the trackpad ribbon cable from the underside of the keyboard.
  • The cable is held in place with adhesive. Work carefully, and be sure to not let the spudger slip and damage any components.
Aggiungi Commento
Remove the six 1.5 mm Phillips #00 screws securing the trackpad to the upper case.
  • Remove the six 1.5 mm Phillips #00 screws securing the trackpad to the upper case.
  • Check your replacement upper case—if it doesn't have this wide T5 screw, remove it to transfer into the replacement.
    • This is an adjustment screw to set the distance of the click of the trackpad—on reassembly, test the click and adjust this screw until it feels right.
Also you will need to remove the T5 screw at the bottom of the trackpad, closest to the edge. It's located right underneath the hill shape in the aluminum. Without it the trackpad will not physically click.
Orioles4L - Replica
I needed the #000 bit instead of #00.
wanderchic - Replica
I also needed #000.
alyssaberns -
#000 is a necessity to remove those six screws - #00 is just too thick to fit.
Michael Sweetser -
Holding the upper case up off the table with one hand, gently push the trackpad up through the upper case. Remove the trackpad from the upper case. Remove the trackpad from the upper case.
  • Holding the upper case up off the table with one hand, gently push the trackpad up through the upper case.
  • Remove the trackpad from the upper case.
Aggiungi Commento
The upper case remains.
  • The upper case remains.
Aggiungi Commento
Conclusione
Altre 39 persone hanno completato questa guida.
Brett Hartt
Membro da: 12/04/2010
106.189 Reputazione
324 Guide realizzate
iFixit Membro di iFixit
Community
113 Membri
6.002 Guide realizzate
I used this guide to replace the keyboard on my macbook air 11, mid 2011.
When I removed the perimeter screws on the keyboard, I then popped all of the 54 or so rivots. I bought a $34 keyboard and installed it with the perimeter screws. But then I bonded the top of each of the rivot shafts with a tiny amount of epoxy cement, after which I used a razor blade to shave each of them to be flush. After re-installing the backlight material, and reassembling the computer, it works PERFECTLY. The Apple store expert had told us that the computer could not be repaired. :-)
Bill Aldridge - Replica
Thank you very much for your clear guide! Even though I had never opened a laptop before, I was able to dig down to my keyboard with your instructions and I'm typing this now with BOTH shift keys :-D
Note: unlike @Bill Aldridge I bought extra screws to replace the rivets and replaced all but four of the rivets using (at my Father's suggestion) flat sharp wire cutters to bite into the stumps of the rivets and then pop them out.
Adam Lee - Replica
Just replaced a top cover following this guide. It worked perfectly! Looks like this trusty old Air is going to get another couple of years of life. Didn't even want to try doing just the keyboard, that just seems brutal. Anyways, thanks for the guide!
nmirza - Replica
I’ve gone used this guide TWICE on the same laptop. My Girlfriend seems determined to keep breaking her laptop! ;-) I may have to buy some screws if there the a third time, some of them are getting a bit worn… Thanks for the guide (again).
nmirza - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 67
Ultimi 30 Giorni: 310
Tutti i Tempi: 44,671
