Salta al contenuto principale
MacBook Air 11" Early 2015 I/O Board Replacement
Cosa ti serve
  1. MacBook Air 11" Early 2015 I/O Board Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 I/O Board Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: passo 3, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement, Battery Connector: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: passo 4, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board Cable: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 I/O Board Replacement: passo 5, immagine 1 di 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2015 I/O Board Replacement, Fan: passo 6, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement, Fan: passo 6, immagine 2 di 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2015 I/O Board Replacement: passo 7, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement: passo 7, immagine 2 di 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Early 2015 I/O Board Replacement: passo 8, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement: passo 8, immagine 2 di 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Early 2015 I/O Board Replacement: passo 9, immagine 1 di 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2015 I/O Board Replacement: passo 10, immagine 1 di 3 MacBook Air 11" Early 2015 I/O Board Replacement: passo 10, immagine 2 di 3 MacBook Air 11" Early 2015 I/O Board Replacement: passo 10, immagine 3 di 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2015 I/O Board Replacement, Battery: passo 11, immagine 1 di 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  12. MacBook Air 11" Early 2015 I/O Board Replacement: passo 12, immagine 1 di 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  13. MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: passo 13, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement, I/O Board: passo 13, immagine 2 di 2
    • Disconnect the I/O board power cable from the logic board by pulling the cable out of its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  14. MacBook Air 11" Early 2015 I/O Board Replacement: passo 14, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement: passo 14, immagine 2 di 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  15. MacBook Air 11" Early 2015 I/O Board Replacement: passo 15, immagine 1 di 3 MacBook Air 11" Early 2015 I/O Board Replacement: passo 15, immagine 2 di 3 MacBook Air 11" Early 2015 I/O Board Replacement: passo 15, immagine 3 di 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  16. MacBook Air 11" Early 2015 I/O Board Replacement: passo 16, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement: passo 16, immagine 2 di 2
    • Use the tip of a spudger to pry under the speaker cable near the connector to lift the connector straight up out of its socket.
  17. MacBook Air 11" Early 2015 I/O Board Replacement: passo 17, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement: passo 17, immagine 2 di 2
    • De-route the cable from its notch in the I/O board.
  18. MacBook Air 11" Early 2015 I/O Board Replacement: passo 18, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Replacement: passo 18, immagine 2 di 2
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
  19. MacBook Air 11" Early 2015 I/O Board Replacement: passo 19, immagine 1 di 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    • In some models this is a 3.1 mm T5 Torx screw.
  20. MacBook Air 11" Early 2015 I/O Board Replacement: passo 20, immagine 1 di 3 MacBook Air 11" Early 2015 I/O Board Replacement: passo 20, immagine 2 di 3 MacBook Air 11" Early 2015 I/O Board Replacement: passo 20, immagine 3 di 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
Conclusione
Altre 9 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.854 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 49
Tutti i Tempi: 6,507
