Salta al contenuto principale
MacBook Air 11" Early 2015 I/O Board Cable Replacement
Cosa ti serve
  1. MacBook Air 11" Early 2015 I/O Board Cable Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Early 2015 I/O Board Cable Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 I/O Board Cable Replacement, Battery Connector: passo 3, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Cable Replacement, Battery Connector: passo 3, immagine 2 di 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Early 2015 I/O Board Cable Replacement, I/O Board Cable: passo 4, immagine 1 di 2 MacBook Air 11" Early 2015 I/O Board Cable Replacement, I/O Board Cable: passo 4, immagine 2 di 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 I/O Board Cable Replacement: passo 5, immagine 1 di 1
    • Lift and remove the I/O board cable.
Conclusione
Sam Goldheart
Membro da: 10/18/12
465.822 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.146 Guide realizzate
Un commento
Your steps were easy to follow. I didn’t have to replace the I/O board cable just re-connect it. Audio is working once again.
Kim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,279
