Introduzione
Use this guide to replace the trackpad, and rejoice in gestures.
  • Shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
When you say:
Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
Nerdily yours,
Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
larryleveen - Replica
The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
Michael Welham -
I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
Allen - Replica
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Aggiungi Commento
In this step you will disconnect the battery to help avoid shorting out any components during service. Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • In this step you will disconnect the battery to help avoid shorting out any components during service.
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
Aggiungi Commento
Remove the following five screws securing the battery to the upper case:
  • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Be carful with the torque when reassembling, these screws seem able to go a little too far and crack through the plastic of the battery.
Daniel Schlaug - Replica
When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
  • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Aggiungi Commento
Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable. Gently slide the ribbon cable out of the ZIF connector.
  • Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
  • Gently slide the ribbon cable out of the ZIF connector.
  • Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
The Trackpad Sensitivity Screw in this model is a T6 Torx screw
andresaldana - Replica
Need a description of why and how much to adjust the sensitivity screw. Do you need to put the screw back to its original position?
blairweaver - Replica
With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it. Use a spudger to flip up the retaining flap. Gently slide the cable out of the connector.
  • With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it.
  • Use a spudger to flip up the retaining flap.
  • Gently slide the cable out of the connector.
Be careful with the retaining piece on the ZIF connector, it released with a bit of a fight but then broke when I tried to close it after reinserting the cable. :(
thea - Replica
Mine popped off too but I managed to get it back on. The clip has two very small bumps on the side that goes down the way so look for them when trying to re-attach it.
David McKeitch -
Mine broke too when re-inserting the cable, had to order a new trackpad because of this. Couldn't get it back in and broke off a small piece of plastic trying to fix the latch. I ordered a new trackpad. I really don't hope this happens with the new trackpad.
Markus -
Note on the two ZIF connections. The smaller connection has it's ZIF lock toward the front of the laptop while the wider ZIF connection faces the KB. I busted the keyboard connections thinking the ZIF was in the opposite direction. Had to replace it with a new trackpad.
I have found that I was able to wiggle the cables out of the ZIFs carefully. idk if this works for all ZIF connections and I'd love to hear anyone who has an opinion on removing ZIF cables. But this makes it much easier to remove and not break the ZIF connections.
Tim - Replica
I work with a Magnifier with a light. Blowing up the subject so you have it really magnified to a high degree helps enormously. I have removed and reattached many zif cables successfully without a hitch. Act like a surgeon.
Paolo Alberto - Replica
Worked fine. Even the keyboard ZIF Cable. Reinserting it was bit tricky.
hschreiber - Replica
I had a bit of trouble getting the keyboard cable back in before noticing that it needs to be off the surface of the trackpad to slide in. The whole arrangement is awkward; just be patient and take it slowly.
mrsharumpe - Replica
Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
  • Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
Phillips #00 screwdriver should be added to the tool list
brian - Replica
The trackpad sold to me by ifixit did not come with the little hinge plates. I had to remove the six other screws and transfer these to the new trackpad. If this is based on using the part as sold here then the photo needs to be corrected to show the six red circles on the phillips screws that are on the trackpad and not on the Mac itself. These are installed quite tightly and I nearly destroyed two of them (on the body side as indicated in the photo) using the correct tool. The six that screw into the trackpad are much more gently installed. I don't think you are generally supposed to remove the six to the chassis of the MBA. Please update this to correct this - UNLESS THE PART FROM APPLE INCLUDES THESE TWO HINGE PLATES AND SCREWS. In that case, please INDICATE THIS difference in the text of the article. It added work and a bit of stress when the two screws were nearly trashed and I realized the new part did not come with replacements. Not good. However, this was otherwise a very easy project. THANKS!
Wade Rackley - Replica
+1 On this comment. The trackpad replacement kit from iFixit does NOT include the hinge plates. The hinge plates must be removed from the removed from the old trackpad (and the additional six screws holding in place). There is the need to replace 12 screws total in this step AND the removal of the old hinge plates to re-use, and re-install on the new, replacement trackpad assembly. This is a critical miss in this step's directions.
coryss -
If someone could please respond ASAP, i was removing one of these screws from the above picture and it was completely destroyed despite my best efforts. The other 5 came out no problem but i have one screw that is stripped beyond use and i have no clue what do to with it at this point
jed falone - Replica
Open the device about 10 degrees. While holding the bottom of the trackpad, press up on the side of the trackpad closest to the logic board to free it from the upper case. Remove the trackpad from the device.
  • Open the device about 10 degrees.
  • While holding the bottom of the trackpad, press up on the side of the trackpad closest to the logic board to free it from the upper case.
  • Remove the trackpad from the device.
Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
Sam Lionheart
Membro da: 18/10/2012
314.321 Reputazione
1.633 Guide realizzate
iFixit Membro di iFixit
Community
117 Membri
5.755 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 66
Tutti i Tempi: 3,218
