Salta al contenuto principale
Mac mini Model A1283 Hard Drive Replacement
Cosa ti serve
  1. Mac mini Model A1283 Hard Drive Replacement, Top Housing: passo 1, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement, Top Housing: passo 1, immagine 2 di 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    Chiedi a FixBot
    Aggiungi Commento
  2. Mac mini Model A1283 Hard Drive Replacement: passo 2, immagine 1 di 3 Mac mini Model A1283 Hard Drive Replacement: passo 2, immagine 2 di 3 Mac mini Model A1283 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Mac mini Model A1283 Hard Drive Replacement: passo 3, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Mac mini Model A1283 Hard Drive Replacement: passo 4, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 4, immagine 2 di 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    Chiedi a FixBot
    Aggiungi Commento
  5. Mac mini Model A1283 Hard Drive Replacement: passo 5, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Keep working around the perimeter, freeing the clips along the final edge.
    Chiedi a FixBot
    Aggiungi Commento
  6. Mac mini Model A1283 Hard Drive Replacement: passo 6, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Mac mini Model A1283 Hard Drive Replacement, Internal Frame: passo 7, immagine 1 di 1
    • In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
    • We will first remove the AirPort antenna, located in the lower left corner of this picture.
    Chiedi a FixBot
    Aggiungi Commento
  8. Mac mini Model A1283 Hard Drive Replacement: passo 8, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 8, immagine 2 di 2
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
    Chiedi a FixBot
    Aggiungi Commento
  9. Mac mini Model A1283 Hard Drive Replacement: passo 9, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 9, immagine 2 di 2
    • The two Bluetooth antenna boards simply lift off the internal frame.
    • Grab the Bluetooth antenna nearest the port side of the computer by the edges of the board and pull it straight up off the internal frame.
    • Pull carefully, as it may offer significant resistance and release suddenly.
    Chiedi a FixBot
    Aggiungi Commento
  10. Mac mini Model A1283 Hard Drive Replacement: passo 10, immagine 1 di 1
    • Remove the antenna board near the front of the mini by pulling it straight up off the internal frame.
    • If necessary, remove the piece of tape securing the antenna leads to the internal frame.
    • Be sure to keep track of the springs under each of the three antenna boards.
    Chiedi a FixBot
    Aggiungi Commento
  11. Mac mini Model A1283 Hard Drive Replacement: passo 11, immagine 1 di 1
    • Use the flat end of a spudger to pry the audio ribbon cable connector up off the audio board.
    Chiedi a FixBot
    Aggiungi Commento
  12. Mac mini Model A1283 Hard Drive Replacement: passo 12, immagine 1 di 1
    • Remove the following four screws securing the internal frame to the bottom housing:
    • Three 6.7 mm Phillips #00 screws
    • One 9.5 mm Phillips #00 screw
    • The screw in the lower right corner of this image is recessed deep in the internal frame and longer than the other three screws. A flashlight and a thin screwdriver aid in removal.
    Chiedi a FixBot
    Aggiungi Commento
  13. Mac mini Model A1283 Hard Drive Replacement: passo 13, immagine 1 di 1
    • Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
    • When reassembling, the wifi antenna wire routes to the inside of the vent and then over the top of the vent.
    Chiedi a FixBot
    Aggiungi Commento
  14. Mac mini Model A1283 Hard Drive Replacement, Hard Drive: passo 14, immagine 1 di 1
    • Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
    Chiedi a FixBot
    Aggiungi Commento
  15. Mac mini Model A1283 Hard Drive Replacement: passo 15, immagine 1 di 1
    • Remove the two Phillips screws securing the side of the hard drive to the internal frame.
    Chiedi a FixBot
    Aggiungi Commento
  16. Mac mini Model A1283 Hard Drive Replacement: passo 16, immagine 1 di 1
    • Use the flat end of a spudger to pry the hard drive thermal sensor board off the adhesive securing it to the side of the hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  17. Mac mini Model A1283 Hard Drive Replacement: passo 17, immagine 1 di 1
    • Remove the strip of tape holding the thermal sensor cable to the hard drive and remove the thermal sensor from the hard drive.
    • You'll want to transfer this thermal sensor to the same position on your new hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  18. Mac mini Model A1283 Hard Drive Replacement: passo 18, immagine 1 di 2 Mac mini Model A1283 Hard Drive Replacement: passo 18, immagine 2 di 2
    • Slide the hard drive toward the speaker to disconnect it from the interconnect board.
    • Lift the hard drive from the edge opposite the fan and remove it from the internal frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 639 persone hanno completato questa guida.
27Commenti sulla guida
The Phillips required on this for me was a size 0, not 00, which was too small.
Symm Vafeades - Rispondi Condividi
Step 13 is not needed and should not be attempted.
Don Woollings - Rispondi Condividi
Ah no you need to remove it to get to the hard drive.
Padraic Hoselton - Rispondi Condividi
You don't need to remove the connector of the HD temperature sensor from the interconnection board, just detach the sensor from the drive. Then you can still get the drive out. My sensor connector unfortunately broke off completly. I managed to solder the sensor wires directly to the tiny contacts on the board :))
Chris Tyson - Rispondi Condividi
Step 16: Is the thermal sensor necessary if I am replacing HDD with an SDD? If so, where should it be attached?
Brian - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 70
Ultimi 30 giorni: 304
Tutti i Tempi: 374,164
