Introduzione
Replacing the hard drive is straight forward and all you need is a Phillips head screw driver. Use this guide to replace a hard drive in your Mac Pro.
IMPORTANT
Make sure you back up your files onto the replacement hard drive before swapping in the machine. If switching to a brand new hard drive you will probably have to re install your operating system in order to keep your computer running as usual.
Also be careful with your hard drive as damaging it can mean that you lose your files.
Parti
Nessuna parte richiesta.
Lift the lever to unlock the case.
  • Lift the lever to unlock the case.
Aggiungi Commento
Remove the side panel of the Mac Pro.
  • Remove the side panel of the Mac Pro.
  • Discharge any static electricity by touching a grounded surface prior to working on any internal components.
Aggiungi Commento
Locate the desired hard drive bay after opening the case .
  • Locate the desired hard drive bay after opening the case .
  • This is usually the drive closest to the front of the case.
Aggiungi Commento
Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove. Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
  • Make sure that the clip used to release the side panel is open or the Hard Drive bays won't slide out
  • Pull the Hard Drive straight out by grabbing the metal sled from the bottom. It may be hard to pull out at first, but after it gets released the sled shouldn't take a lot of effort to remove.
Aggiungi Commento
When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures. Locate the four 6-32 type screws on the Hard Drive sled. Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
  • When handling the hard drive hold it by the sled or sides be sure not to touch the green circuit board visible in all 3 pictures.
  • Locate the four 6-32 type screws on the Hard Drive sled.
  • Using a Phillips head screw driver remove the four screws and separate the metal sled from the Hard Drive
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Charlie Franklin
Membro da: 12/10/2014
673 Reputazione
1 Guida realizzata
Cal Poly, Team 6-24, Maness Fall 2014 Membro di Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 94
Tutti i Tempi: 7,650
