Salta al contenuto principale
MSI GE62 Apache Pro 004 Speakers Replacement
Cosa ti serve
  1. MSI GE62 Apache Pro 004 Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Start with the bottom of the laptop facing up.
  2. MSI GE62 Apache Pro 004 Speakers Replacement: passo 2, immagine 1 di 2 MSI GE62 Apache Pro 004 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
  3. MSI GE62 Apache Pro 004 Speakers Replacement: passo 3, immagine 1 di 3 MSI GE62 Apache Pro 004 Speakers Replacement: passo 3, immagine 2 di 3 MSI GE62 Apache Pro 004 Speakers Replacement: passo 3, immagine 3 di 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
  4. MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: passo 4, immagine 1 di 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: passo 4, immagine 2 di 3 MSI GE62 Apache Pro 004 Speakers Replacement, Speakers: passo 4, immagine 3 di 3
    • Remove the four screws, two on each speaker, with a PH1 screwdriver.
  5. MSI GE62 Apache Pro 004 Speakers Replacement: passo 5, immagine 1 di 2 MSI GE62 Apache Pro 004 Speakers Replacement: passo 5, immagine 2 di 2
    • Gently pull back the speakers until they release from their socket.
    • Keep track of which speaker went where. The connectors for the speakers are unique; you cannot use a speaker that should go on the right side on the left side and vice versa.
Conclusione
USF Tampa, Team S15-G5, Boczar Spring 2018 Membro di USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,490
