Introduzione
This guide will show how to lubricate the volume slider after you have opened up the base of the phone. Your volume slider will operate smooth after completing this guide.
Unplug the device before proceeding. Remove the phone cord from the phone jack from the base of the headset.
  • Unplug the device before proceeding.
  • Remove the phone cord from the phone jack from the base of the headset.
    • Use a plastic opening tool to remove the phone cord.
Aggiungi Commento
Remove the phone cord screw cap. Unscrew the 7.5mm screw. Remove the screw cap.
  • Remove the phone cord screw cap.
    • Unscrew the 7.5mm screw.
    • Remove the screw cap.
  • Remove the cord from the phone base.
Aggiungi Commento
Use finger to remove the battery cover. Use finger to remove the battery cover.
  • Use finger to remove the battery cover.
Aggiungi Commento
Remove the Volume Dial by gently grasping the dial and pulling away from the base. Remove the Volume Dial by gently grasping the dial and pulling away from the base.
  • Remove the Volume Dial by gently grasping the dial and pulling away from the base.
Aggiungi Commento
Remove the 6 screws from the base shell.
  • Remove the 6 screws from the base shell.
    • Remove the 3 12mm screws with the Philips head #1 screw driver.
    • Remove the 3 18mm screws with the Philips head #1 screw driver.
Aggiungi Commento
Pry off the base shell using a Plastic Opener Tool. Pry off the base shell using a Plastic Opener Tool.
  • Pry off the base shell using a Plastic Opener Tool.
Aggiungi Commento
Turn the tuning slider counter clockwise all they way. Apply lubricant to slider rail
  • Turn the tuning slider counter clockwise all they way.
  • Apply lubricant to slider rail
  • Turn the tuning slider back and forth to distribute lubricant
  • CAUTION: Make sure lubricant does not circuit board. This can damage the circuit board.
Aggiungi Commento
Conclusione
Alles Rebel
Membro da: 20/09/2012
63 Reputazione
3 Guide realizzate
Cal Poly, Team 16-59, Forte Fall 2012 Membro di Cal Poly, Team 16-59, Forte Fall 2012
CPSU-FORTE-F12S16G59
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 563
