Introduzione
The WiLife Outdoor Camera has a high failure rate, often malfunctioning after the warranty expires. Four faulty capacitors are the most common cause of failure.
This guide is based on the work of Steven Markham
Background
The WiLife Security Camera System was developed and sold by WiLife, Inc. This system was originally called LukWerks. Wilife was acquired by Logitech Corp in November 2007. The system name was changed to WiLife. In September 2010, Logitech discontinued support and production of the WiLife Security Camera System.
Cosa ti serve
Obtain (4) 1000uF capacitors rated for 25 volts. The replacement capacitors featured in this guide were purchased from Digi-key. Digi-key part number: UHE1E102MHD6. http://search.digikey.com/scripts/DkSear...
Additional suggested tools for this repair are pictured.
Unscrew all four phillips head screws in each corner (green highlight).
Disconnect power cable (yellow highlight).
Lift and remove the clear front plastic lens cover.
Lift the circuit board and camera assebly out of the case.
Carefully separate the LED assembly from the four small connectors (highlighted in blue). Note: This step is not required for this repair. However, it reduces the possibility of inadvertent damage during the process.
Suggestion: Before full reassembly, reattach the LED module, place the board and camera module into the case and reconnect the A/C cable to ensure proper operation.
Caution: Be mindful of the dangerous high voltage that exist in this device when powered and for a short time afterward.
Altre 6 persone hanno completato questa guida.
