Salta al contenuto principale
Logitech Webcam Pro 9000 Motherboard Replacement
Cosa ti serve
  1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: passo 1, immagine 1 di 2 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: passo 1, immagine 2 di 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Motherboard Replacement: passo 2, immagine 1 di 2 Logitech Webcam Pro 9000 Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: passo 3, immagine 1 di 3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: passo 3, immagine 2 di 3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: passo 3, immagine 3 di 3
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
  4. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: passo 4, immagine 1 di 2 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: passo 4, immagine 2 di 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
  5. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: passo 5, immagine 1 di 2 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: passo 5, immagine 2 di 2
    • Use tweezers to grasp the white wire connector on the back of the motherboard.
    • Wiggle the connector back and forth to remove it from the socket.
  6. Logitech Webcam Pro 9000 Motherboard Replacement: passo 6, immagine 1 di 2 Logitech Webcam Pro 9000 Motherboard Replacement: passo 6, immagine 2 di 2
    • Desolder the joint on the front of the motherboard to completely detach the USB cable.
    • Follow this link to learn how to properly solder and desolder your parts.
  7. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: passo 7, immagine 1 di 1
    • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
  8. Logitech Webcam Pro 9000 Motherboard Replacement: passo 8, immagine 1 di 3 Logitech Webcam Pro 9000 Motherboard Replacement: passo 8, immagine 2 di 3 Logitech Webcam Pro 9000 Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove the camera from the motherboard by desoldering the two connections as shown.
Conclusione
Cory Davis
Membro da: 04/14/13
236 Reputazione
4 Guide realizzate
Cal Poly, Team 12-34, Amido Spring 2013 Membro di Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,060
