On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
  • On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
Aggiungi Commento
Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
  • Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
  • Once the cap is loosen, simply lift the cap out to reveal the batteries.
Aggiungi Commento
Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation. Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
  • Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
Aggiungi Commento
Conclusione
USF Tampa, Team 1-29, Donnelly Fall 2014 Membro di USF Tampa, Team 1-29, Donnelly Fall 2014
USFT-DONNELLY-F14S1G29
1 Membro
1 Guida realizzata
i bought Harmony 350, and it's imposibble to open this cover, I tried to open this cover for few hours wihout luck, my fingers hurt. Return this crap to shop, I have also Harmony 700 which in it cover open easy.
peter.mac83 - Replica
This instruction is USELESS the catch is too strong! Note all the other questions about the enclosure.
Errol - Replica
it’s impossible !!!
Pascal jade - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 37
Tutti i Tempi: 835
