Salta al contenuto principale
Lite-On LightScribe SHM-165H6S Drive Belt Replacement
Cosa ti serve
  1. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: passo 1, immagine 1 di 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Chassis: passo 1, immagine 2 di 2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 2, immagine 1 di 3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 2, immagine 2 di 3 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 2, immagine 3 di 3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 3, immagine 1 di 1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 4, immagine 1 di 1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 5, immagine 1 di 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 5, immagine 2 di 2
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: passo 6, immagine 1 di 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement, Drive Belt: passo 6, immagine 2 di 2
    • Extend the tray so that the belt is accessible.
    • Remove the old belt using tweezers.
  7. Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 7, immagine 1 di 2 Lite-On LightScribe SHM-165H6S Drive Belt Replacement: passo 7, immagine 2 di 2
    • Carefully replace with the new belt by wrapping it around the larger gear first, followed by the smaller gear.
Conclusione
Altre 5 persone hanno completato questa guida.
James Biggs
Membro da: 10/12/11
596 Reputazione
3 Guide realizzate
Cal Poly, Team 6-5, Regan Fall 2011 Membro di Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Membri
6 Guide realizzate
Un commento
In case anyone is interested, I used a 11/16” OD x 9/16” I.D. x 1/16” wall, for this exact drive (was a tight fit) and seems to work perfect.
I was so tired of replacing rubber bands every few months!
And yes this is an “O-ring”  it should be less than a buck five eighty at your local big box hardware store.
Jim Mccalb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 6,522
