Introduzione
If the disc tray has fallen out of alignment or has broken, you will need to replace it.
Insert an open paper clip into the small hole on the left side of the faceplate. The tray should click open, extend it fully.
  • Insert an open paper clip into the small hole on the left side of the faceplate.
  • The tray should click open, extend it fully.
Aggiungi Commento
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate. Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Aggiungi Commento
Pull the faceplate away from the main chassis.
  • Pull the faceplate away from the main chassis.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
Aggiungi Commento
Lift the top and bottom chassis straight up in order to remove them. Lift the top and bottom chassis straight up in order to remove them.
  • Lift the top and bottom chassis straight up in order to remove them.
Aggiungi Commento
Extend the tray fully. Push the tab on the right side to the left. Push the tab on the left side to the left.
  • Extend the tray fully.
  • Push the tab on the right side to the left.
  • Push the tab on the left side to the left.
  • Remove the tray carefully.
Aggiungi Commento
Guide the replacement tray under the beige tabs. Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray. Check to see that the tray extends and closes smoothly.
  • Guide the replacement tray under the beige tabs.
  • Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray.
  • Check to see that the tray extends and closes smoothly.
Aggiungi Commento
Conclusione
James Biggs
Membro da: 12/10/2011
596 Reputazione
3 Guide realizzate
Cal Poly, Team 6-5, Regan Fall 2011 Membro di Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,205
