Introduzione
Is your disco ball not giving off the right groovy colors that it once did? This guide will teach you how to replace the colored panels so you can get back to partying!
Parti
Nessuna parte richiesta.
Unplug the device to avoid injury.
  • Unplug the device to avoid injury.
  • Turn the device over, so that the base is on top.
Aggiungi Commento
Compress the tab by pushing towards the center of the device with a spudger. While compressing the tab, peel the base away from the rotating head. While compressing the tab, peel the base away from the rotating head.
  • Compress the tab by pushing towards the center of the device with a spudger.
  • While compressing the tab, peel the base away from the rotating head.
Aggiungi Commento
If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
Aggiungi Commento
Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches. Insert a new color panel by pushing it into place while lining up the tabs with the notches. Insert a new color panel by pushing it into place while lining up the tabs with the notches.
  • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
  • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
Aggiungi Commento
Conclusione
Nick Kaprielian
Membro da: 14/01/2014
495 Reputazione
4 Guide realizzate
Cal Poly, Team 17-3, Forte Winter 2014 Membro di Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 358
