Salta al contenuto principale
Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal
Cosa ti serve
  1. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: passo 1, immagine 1 di 1
    • Turn the device over so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: passo 2, immagine 1 di 1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: passo 3, immagine 1 di 2 Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: passo 3, immagine 2 di 2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
Conclusione
Cal Poly, Team 17-3, Forte Winter 2014 Membro di Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 565
