Salta al contenuto principale
Liquid Damage Technique
Cosa ti serve
  1. Liquid Damage Technique, Top Casing: passo 1, immagine 1 di 1
    • Power down and unplug the device.
  2. Liquid Damage Technique: passo 2, immagine 1 di 1
  3. Liquid Damage Technique: passo 3, immagine 1 di 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Liquid Damage Technique: passo 4, immagine 1 di 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Liquid Damage Technique: passo 5, immagine 1 di 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Liquid Damage Technique: passo 6, immagine 1 di 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Liquid Damage Technique: passo 7, immagine 1 di 2 Liquid Damage Technique: passo 7, immagine 2 di 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Liquid Damage Technique: passo 8, immagine 1 di 2 Liquid Damage Technique: passo 8, immagine 2 di 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Liquid Damage Technique, Bottom Casing/Motherboard: passo 9, immagine 1 di 2 Liquid Damage Technique, Bottom Casing/Motherboard: passo 9, immagine 2 di 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
  10. Liquid Damage Technique, Liquid Damage Technique: passo 10, immagine 1 di 1
    • If the spilled substance is dry use a cleaning tool such as a toothbrush with soft bristles, so you do not damage the device, to brush off as much of the foreign material as possible.
  11. Liquid Damage Technique: passo 11, immagine 1 di 1
    • Dry off circuit board with kitchen paper; using other types of paper products such as toilet paper will fall apart. Be sure not to rub but carefully apply pressure to dry up wet spots.
  12. Liquid Damage Technique: passo 12, immagine 1 di 1
    • Clean off the components to make sure the rest of the residue comes off by using a chemical gasoline or another solvent that contains one substance that evaporates quickly.
Conclusione
After the device is cleaned and put back together it should work properly.
Derek Myers
Membro da: 10/04/11
288 Reputazione
5 Guide realizzate
Cal Poly, Team 21-21, Maness Fall 2011 Membro di Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Membri
12 Guide realizzate
Un commento
I did all of this still not working it gets hot only but doesn’t turn it on.
DM MG - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 7,160
