Introduzione
You will be desoldering and replacing the power connector.
Turn the router over so that all four of its feet are facing upwards.
  • Turn the router over so that all four of its feet are facing upwards.
Aggiungi Commento
Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • Remove the rubber inserts inside the the two purple feet located on the router's front case.
  • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Aggiungi Commento
Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
Aggiungi Commento
Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Aggiungi Commento
Slide the board unit out and up.
  • Slide the board unit out and up.
Aggiungi Commento
Flip the  circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
  • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
  • Slide the back cover out and away from the circuit board.
Aggiungi Commento
Turn the circuit board over and identify the solder connections you will desolder.
  • Turn the circuit board over and identify the solder connections you will desolder.
    • The connections for the power connector are shown in red.
Aggiungi Commento
Desolder the connection by following iFixit's guide to repairing soldered connections: How To Solder and Desolder Connections.
Aggiungi Commento
Conclusione
Alex Do
Membro da: 12/10/2011
48 Reputazione
1 Guida realizzata
Cal Poly, Team 3-4, Regan Fall 2011 Membro di Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,480
