Introduzione
If the network port of your Linksys WAP 11 is faulty, the device can not send or receive information through a wired connection. Replacing the network port may resolve communication issues.
Cosa ti serve
Be sure the ethernet and power cables are disconnected from the device.
You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
At this point, you may want to remove the antenna leads as well.
Once the antennas have been removed, proceed to remove the remaining three phillips screws fastening the motherboard to the case.
Once the screws are removed, your motherboard will separate from the housing.
Ifixit soldering guide Soldering and desoldering have the potential for harm, always wear propper eye protection and other personal protective equipment while performing either action!
Turn the main circuit board around and using a soldering iron and desoldering wick desolder the 12 pins that secure the port to the main board.
