Introduzione
Replace the pressure gauge in your CNC floor drive pump if the gauge appears to be inaccurate, is malfunctioning or has stopped working all together.
Parti
Using a flat head screwdriver, pry up an edge of the gauge cover. Remove the gauge cover.
  • Using a flat head screwdriver, pry up an edge of the gauge cover.
  • Remove the gauge cover.
Aggiungi Commento
No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing. Pry up a corner of the gauge face plate.
  • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
  • Pry up a corner of the gauge face plate.
  • Use pliers to pull off the gauge face plate.
    • Be careful when prying off the face plate, as the edges are sharp.
  • Use pliers to remove the internal gauge mechanics.
Aggiungi Commento
Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise. Pull the gauge out of its housing.
  • Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise.
  • Pull the gauge out of its housing.
Aggiungi Commento
Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into. Place a new O-ring into the hole.
  • Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into.
  • Place a new O-ring into the hole.
Aggiungi Commento
Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
  • Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
Aggiungi Commento
Thread the new gauge into the floor pump by turning it clockwise in its housing. Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body. Gauge performance will not be affected by its position, so long as it is snug.
  • Thread the new gauge into the floor pump by turning it clockwise in its housing.
  • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
  • Allow at least 30 minutes for the thread locker to set.
  • Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Removing the old face plate and gauge internals was a blast. =) However, Step#6 of the guide above says;
"Allow at least 30 minutes for the thread locker to set.
Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it."
The guide that came with the replacement parts says to "Let the Locktite cure for 1 day before pumping."
I think I used plenty of Locktite, I tightened the gauge and backed it off 1/4 turn to face the handle, I'm gonna let it cure overnight and hope for the best.
john - Replica
Seems to have worked. Next time I will reads all the instructions first. One more thing, "Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it." I don't have any way of testing the highest psi. I pumped to my tires highest psi and waited about 2 minutes and no change, so I'm calling this a successful repair. Thank you very much Lezyne, and specifically Colton Arbuckle for your help. =)
john - Replica
Linea Traguardo
iRobot
Membro da: 24/09/2009
1 Reputazione
750 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,784
