Introduzione
The duplex unit allows the printer to print on the front and back of a page without having to manually flip over the paper.
Hold the button down with flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
  • Hold the button down with flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
Aggiungi Commento
Remove the duplex unit from the back of the printer with the duplex unit is facing up. Remove the duplex unit from the back of the printer with the duplex unit is facing up.
  • Remove the duplex unit from the back of the printer with the duplex unit is facing up.
Aggiungi Commento
Conclusione
Once the duplex unit is installed, your printer will be able to print on the front and back of pages.
Raymond
Membro da: 15/01/2013
42 Reputazione
7 Guide realizzate
Cal Poly, Team 18-38, Regan Winter 2013 Membro di Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 683
